Dowty Washer Size For Sump Plug
7 replies to this topic
#1 MatthewsDad
MatthewsDad
  • 814 posts
Posted 22 June 2018 - 11:34 AM
After a recent oil change I have an oil weep from the sum plug. It's slight but not small enough to completely ignore. For the oil change I used as always a new copper sealing washer. I have nipped up the bolt a couple of times but don't want to take it any further. I'll try a dowty washer but just wanted to check the correct size as there is some conflicting information in previous threads, and some sizes are expressed in BSP.
Many thanks
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 22 June 2018 - 11:40 AM
I think its classed as a 5/8 UNC thread...
my vernier is 4 miles away at the workshop so can't measure one.
#3 GraemeC
GraemeC
  • 7,438 posts
Posted 22 June 2018 - 12:54 PM
I have it in mind that a Ford Mondeo one works, possibly could be M18?
http://www.halfords....for-ford-mondeo
Edited by GraemeC, 22 June 2018 - 12:55 PM.
#4 Someone called James
  • 26 posts
Posted 23 June 2018 - 08:05 PM
I used a Dowty Washer when refitting my sump plug, I'm fairly sure it was 3/8 BSP.. I think the I.D. of the washer was around 14mm if I remember correctly, it was a similar size to the original copper washer anyway.
James.
#5 Spider
  • 14,889 posts
Posted 23 June 2018 - 08:13 PM
The Plug, as Retroman has mentioned, is 5/8" in diameter.
You'll only need a Dowty that's around that inside diameter, which will be 5/8", 16 mm or 3/8" BSP.
I've not used a Dowty Washer, however, the Red Fibre ones are also good, cheap and really easy to come by.
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 23 June 2018 - 08:19 PM
M18 wasn’t too far out then!
I’ve used the Mondeo ones from Halfords a few times - they’re snug so you have to carefully screw them onto the sump plug
#7 Spider
  • 14,889 posts
Posted 23 June 2018 - 08:48 PM
I don't see why an M18 one wouldn't work, the head on the plug is well big enough.
#8 MatthewsDad
MatthewsDad
  • 814 posts
Posted 24 June 2018 - 01:47 PM
Thanks everyone, I picked up a M18 as one was available locally. Fingers crossed.
