I've yet to see an A series that doesn't puff out a bit of blue smoke
Still Puffing Smoke
#16
Posted 21 June 2018 - 01:06 PM
#17
Posted 21 June 2018 - 02:09 PM
Yes that's true. You are correct with the previous posts. Once I fitted the spi head the smoke stopped for a while. I had the spi head skimmed and the guy in the machine shop said that the valve guides had a little play but nothing to worry about. I just want to know for certain that it's the head that is the problem
It could be worth looking at the rocker shaft too. If these are worn (as they often are) it can allow a lot more oil out between the rocker bushes which then gives the valve seals a lot more work to do.
#18
Posted 21 June 2018 - 02:12 PM
The thing is that the car also has megajolt fitted. Unfortunately no one down our area can tune it up. Its a very reliable system but I could sell the megajolt system and the mg engine and two heads, the big valve head and spi head as well as a hif 44. I got the chance of a 998 that has only done 33k and drives lovely. The 998 has a hif 38 and stage one kit too. I don't really need the extra power as I don't race the car about. Also I would love to go to a 3.1 diffs as the 3.44 is too low geared for me as when I use the mini it's usually for long distances with the family.
998s are great but if you go higher than a 3.44 diff it kills them. If what you want to do is use the car for long distances with the family and you don't race it about I think you're better off with the larger engine, and it'll pull the higher diff ratios.
#19
Posted 21 June 2018 - 02:28 PM
There's no reason why they need to. Something's wrong if they do.
#20
Posted 21 June 2018 - 02:50 PM
My minis don't smoke unless on choke
#21
Posted 21 June 2018 - 03:23 PM
Posted 21 June 2018 - 03:25 PM
#23
Posted 22 June 2018 - 09:25 AM
#24
Posted 22 June 2018 - 09:27 AM
#25
Posted 22 June 2018 - 10:06 AM
#26
Posted 22 June 2018 - 10:43 AM
Well it won't be any worse than it is now and with the valves coated like that the head certainly needs sorting.
#27
Posted 22 June 2018 - 10:47 AM
#28
Posted 22 June 2018 - 10:53 AM
Get new valve springs too if you do the head - they're not that expensive.
#29
Posted 22 June 2018 - 11:08 AM
#30
Posted 22 June 2018 - 11:14 AM
