Still Puffing Smoke
Posted 20 June 2018 - 04:16 PM
Posted 20 June 2018 - 04:41 PM
valve stem seals
Posted 20 June 2018 - 05:06 PM
Posted 20 June 2018 - 05:15 PM
Posted 20 June 2018 - 05:28 PM
Worn valve guides that have worn out the new valve stem oil seals quickly.
Posted 20 June 2018 - 05:30 PM
Posted 20 June 2018 - 08:03 PM
Posted 20 June 2018 - 08:04 PM
How come the valve seals are only a few months old? Was any other work done on the head?
If the guides are worn you'll need to have the valve seats recut. Basically you'll need to overhaul the head. It'll be worth it though if it needs it.
Posted 20 June 2018 - 08:08 PM
Is there a way I can test to see if its definitely the guides without stripping????
If you fancy taking the manifolds off you may with torch and mirrors be able to see the valves in the ports. Mine were noticeably covered in oil when the guides were worn although I removed the head to look.
Posted 20 June 2018 - 08:50 PM
Posted 20 June 2018 - 09:50 PM
I've been looking through some of your previous posts. Tell me if I'm wrong but it looks like last September you were concerned about oily valves on the MG head and you ended up replacing the head with an unleaded SPi head. It appears you may still have the same problem with this head but there has been a question too over rich running under certain conditions. You also did a compression test on the engine and found that the wet and dry compressions were very close - this would indicate that the condition of the rings and cylinders are good. If this is the case why not have the MG head reconditioned and add hardened valve seats as this should make for a nice engine. Finally get the fuelling sorted on a rolling road to take care of that side of things.
Posted 20 June 2018 - 11:19 PM
Is it actually using oil on the dipstick? Do you know if pistons have the standard oil control ring below compression rings as well as the scraper oil ring at the bottom of the piston? It could even be the oil rings lost their tension.
Posted 21 June 2018 - 06:39 AM
May sell this engine and stick the 998 back in the way I feel
Or, if the 998's a good engine, you could stick that back in and then take your time and rebuild the 1275.
Tha's a nightmare when you just want it sorted and working but don't give up, you often end up with something better than you thought if you work through the difficulties.
Posted 21 June 2018 - 09:34 AM
Posted 21 June 2018 - 11:58 AM
