Swivel Ball Joint Sizes
Posted 20 June 2018 - 11:18 AM
My Elf has been fitted with 8.4 vented discs & calipers. I need to replace a worn ball joint, I have bought a replacement ball joint kit but find it is smaller than the ball joint (which I am struggling to remove)
Would I be correct in presuming the car may have Metro hubs?
Would I also be correct in presuming the Metro ball joints are bigger?
Posted 20 June 2018 - 11:39 AM
Metro ball joints are totally different to Mini ones.
metro uprights are not really suitable for use on a Mini. (there are some aftermarket hubs that are suitable that use Metro ball joints)
note only MK1 Metro ball joints fit the Mini arms, the later ones had a different taper.
Posted 20 June 2018 - 02:24 PM
DUF how about a picture of your swivels - might help us to help you
Posted 20 June 2018 - 03:20 PM
Hi,
The metro balljoints are a one piece disposable item unlike the mini ones you can strip down and shim.
It should be easy to tell which by looking at the rubber boot.
Edited by Bat, 20 June 2018 - 03:21 PM.
Posted 20 June 2018 - 03:31 PM
They are also 'kin tight!! I don't have a socket or ring spanner to fit. I tried the pikey manner of a pair if 18"stilsons, still no joy! Nowt daft like left hand threads?
Posted 20 June 2018 - 03:36 PM
you need the right size socket. and there is even less space on the bottom one.
yes they are Metro hubs.
Posted 20 June 2018 - 03:40 PM
Looks like metro ones to me.
Mini one:
http://minispares.co...px|Back to shop
Metro
http://i.ebayimg.com...0-1/s-l1000.jpg
Posted 20 June 2018 - 05:02 PM
You will probably have to get a cold chisel on it to shift it. they are normally seized on!
Posted 20 June 2018 - 05:55 PM
Great pics. Looking at the lower control arm rubbers in the background looks like you have a few more things to replace.
Would make your life far easier to clean up a bit on the grease and oil and remove the whole hub and do the work on a bench with a decent vice.
Regreasing of wheel bearings and replacing CV gaitors would be advisable too.
Posted 20 June 2018 - 06:25 PM
I'll just add a Caution Note here regarding Ball Joints for these hubs when fitted to a Mini.
I've found that not all Metro type Ball Joints have enough swivel angle to suit a Mini, they need to have at least 550 of movement or they can break.
I know Delphi ones are OK however, in this regards, the QH ones do not.
Posted 20 June 2018 - 06:35 PM
As the car is sitting very low, I'm changing the rubber springs & fitting HiLos. I will be replacing any perished rubber joints whilst I am working on it.
I did think the ball joints would be a doddle to do............
Posted 20 June 2018 - 09:58 PM
Hi,
Mini balljoint should NEVER be shimmed after theyre used.
Posted 21 June 2018 - 08:45 AM
Get rid of those Metro hubs. One of my Minis had Metro hubs when I bought it - talk about understeer!!!!! dreadful and most unMini like. My first job was to replace them - relief.
Posted 21 June 2018 - 10:01 AM
I'm looking for the correct joints, I have seen them 1980-1984, 1984-2002. Anyone know what the difference is?
I beleive the suspension was changed in 1990 as bottom ball joints from that date have a three bolt fitting.
My car appears to have identical joints top & bottom, but am not sure what the difference is between a pre & post '84 ball joint.
Any advice on how to check this would be most appreciated.
Posted 21 June 2018 - 10:06 AM
see first reply. you need MK1 ones as the later ones have the incorrect taper.
