Extra Long Gear Lever
15 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 17 June 2018 - 04:57 PM
Is there such a thing available. Would prefer not to have an extension piece
#2 nicklouse
  • 18,583 posts
Posted 17 June 2018 - 05:37 PM
get the welder out or see if you can find a Mole one as i believe they are longer.
#3 Spider
  • 14,849 posts
Posted 17 June 2018 - 06:33 PM
Yes, as Nick has said, the MoKe ones are longer, but can be hard to find, though if you really want one I maybe able to sort you for that.
However, I'll also point out that I don't use the stock Moke ones as because they are longer, the 'throw' at the gearknob is crazy, way to far, 1st & 3rd are just about in the speedo glass and 2nd & 4th are almost on the seats. Dreadful things, but avoids the need to also go to the Gym.
I make mine from the Mini Spares 'short shifter', reshaped and add a bit to it, in fact, it ends up a little longer than a standard Moke one, but has an acceptable throw.
#4 GraemeC
GraemeC
  • 7,438 posts
Posted 17 June 2018 - 06:42 PM
KAD do a Moke version of their short shift too
Edited by GraemeC, 17 June 2018 - 06:42 PM.
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 June 2018 - 09:09 PM
I was actually thinking of welding the mini spares quick shift up with an extra bit from a spare lever I have. Was just concerned about getting enough penetration. I give that a go. Cheers all.
Edited by HUBBA.HUBBA, 17 June 2018 - 09:09 PM.
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 June 2018 - 09:11 PM
Yes I saw that one. Was tempted, but already have a new mini spares one.
#7 Spider
  • 14,849 posts
Posted 18 June 2018 - 05:59 AM
The ones I do, to extend them, I use a piece if 1/2" steel rod, drill & tap it 5/16 UNC in one end and give it a deep chamfer, then turn the other end to 5/16" and cut a 5/16" UNC Thread for the knob, bit of loctite & screw them together. As the short shifter is chrome, to finish them off, I lightly grease the stick, then slide over some thin wall heat shrink & shrink it down. The grease is to stop the heat shrink getting 'craters' as it comes in to contact with the cooler metal underneath.
I've come across a few that have been welded and they seem to break all too easy.
#8 Spider
  • 14,849 posts
Posted 18 June 2018 - 09:35 AM
#9 viz139
viz139
  • 670 posts
  • Local Club: Irish Mini Owners Club
Posted 18 June 2018 - 11:40 AM
The Austin 1100/1300 range had longer gear sticks and maybe the Metros had too.
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 19 June 2018 - 03:16 PM
Bit the bullet and ordered a KAD one.14cm longer for the moke one!
#11 mrvital
mrvital
    Just On Tickover
  • Just Joined
  • 8 posts
Posted 15 August 2019 - 03:09 AM
How did it turn out? and pictures? i was thinking of ordering one and using the extra length to bend the back and then up to move the shifter knob further back.
#12 Ethel
  • 25,922 posts
Posted 15 August 2019 - 07:08 AM
If you're looking to weld one, you could drill & tap it together with some threaded rod first.
#13 Ethel
  • 25,922 posts
Posted 15 August 2019 - 07:18 AM
A bit of an aside, but what's the matting? Looks to mould quite well to the floor contours if it's off the roll. Swimming pool, farm supplies...?
#14 Spider
  • 14,849 posts
Posted 15 August 2019 - 07:27 AM
It's actually original floor mats that were fitted to Aust. made Mokes from about 1975 on.
It's very similar to this stuff;-
https://www.clarkrub...ynalite-matting
I find them really good in the Moke, all the crud falls through,so you're left with low slip mats, then lift them out and scoop the sand / dirt / mud out with a shovel when you get home :D
#15 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 August 2019 - 11:57 AM
works great. There should be some pictures on my build thread in my signature below
