I had the same issue and I fiddled with carb settings only to find out that there was an issue with the ignition side of the system. I ahd replaced the plugs numerous times but ended up the same. It was the points, condenser, cap, rotor and leads that I replaced with an electronic set-up and then adjusted the carb mixture and she runs like a champ.
20 replies to this topic
#16
Posted 13 June 2018 - 03:23 AM
#17
Posted 13 June 2018 - 05:39 AM
To check if oil or fuel on plugs after running - remove plugs and smell them.
#18
Posted 13 June 2018 - 09:58 AM
Guys thanks for your replies. Some good pointers and things for me to check. The timing was checked out a few months ago and said to be fine, but I have never changed anything on the ignition side, other than leads and plugs since I've had it running.
Im away for a few days now but will check a few things when I get back and let you know how I get on.
Thanks again.
Thanks again.
#19
Posted 14 June 2018 - 08:52 PM
Worn stem seals really show up on first start of the day, normally a good puff of BLUE smoke which then clears.
For me I would be whipping this down to a rolling road to get things set up correctly rather than trying multiple things. Something that does get mentioned is plugs and the right type for then engine as they have different ratings.
Some foul other don’t. Never been into the theory behind this but I’m sure someone more knowledgeable can shed some light on this.
#20
Posted 03 August 2018 - 11:16 PM
Been away for a while, went for a quick drive and checked the plugs again, the ends seem sooty but not wet, but there is wet oil/ fuel on the thread of the plug. It smells of fuel but can't really be sure. The reason I say, is because I use the Halfords classic oil which is green in colour. And the wetness on the plug does appear a little greenish. Anyway I've got myself booked in for a tune on rolling road next week. So we will see what we find.
#21
Posted 04 August 2018 - 12:27 AM
what is the fuel set up`?
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
