Mk1 Austin Countryman
156 replies to this topic
#121 minimikej
minimikej
  • 347 posts
Posted 11 May 2020 - 06:02 PM
Got the new bulkhead trial fitted this afternoon. I was worried that no way were the gaps going to close, but when I managed to get some bolts through the steering rack jigs it pulled together without any problems.
49883769647_810c1d5db7_b.jpg2020-05-11_05-45-43 by Mike Jackson, on Flickr
49882937823_b34a935cc4_b.jpg2020-05-11_05-45-59 by Mike Jackson, on Flickr
And here you can just about make out the subframe mounting holes clearing nicely. There's a bolt through the lower offside.
49883774177_1f123048ce_b.jpg2020-05-11_05-46-30 by Mike Jackson, on Flickr
It looks like I might be able to get the spot welder in to join the parcel shelf to the bulkhead if I rotate the electrodes to meet slightly off centre.
Now I need to remove it all again and strip back the e-coating where the welding will be done.
#122 KTS
KTS
  • 2,414 posts
Posted 11 May 2020 - 06:19 PM
that's a decent step forward.
oddly enough i was working on the back subframe mounts of mine the other day and wondered why the floor panel had a couple of cutouts where it meets the toeboard.  now i know !
#123 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 16 May 2020 - 03:25 PM
Big step forward for sure, will it still retain the twin bolt subframe set mike? i see m-machine now sell the little conversion panels
So nice seeing some fresh steel up front
#124 minimikej
minimikej
  • 347 posts
Posted 18 May 2020 - 02:59 PM
Ah what??! I missed that!
Yes, it's keeping the twin bolt subframe, I've started spot welding the bulkhead in, will post some pics in a bit. Last bits of grot starting to disappear at last
#125 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 18 May 2020 - 04:44 PM
grreeaatt project really coming together, look forward to the updates
#126 minimikej
minimikej
  • 347 posts
Posted 19 May 2020 - 06:09 PM
So, in between phone calls trying to land a new job, been proper busy in the garage.
New top dash rail installed and spot welded in
49913322811_a2f79f5897_b.jpg2020-05-19_06-43-50 by Mike Jackson, on Flickr
Inner wings offered up and clamped in place. Bit of a struggle there to be honest. The profile of the flitch panel where the bend is does not match the profile of the parcel shelf I left in situ. That's going to take quite some persuasion.
49912809503_1be44690f8_b.jpg2020-05-19_06-44-11 by Mike Jackson, on Flickr
49913623302_e6b546ef6c_b.jpg2020-05-19_06-44-53 by Mike Jackson, on Flickr
Next job is to attach the inner wings to the bulkhead and the floor pans. Then I will worry about the A-posts and how on earth I can swap them out whilst leaving the jig intact.
#127 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 29 May 2020 - 06:36 AM
She is really coming together glad you keeping the twin bolt frame. Cant wait to see this done..
#128 minimikej
minimikej
  • 347 posts
Posted 02 June 2020 - 06:09 PM
Making the absolute most of the last of the fine weather today.
Repairs to the parcel shelf front edge, inner wings are in and partly welded!
Parcel shelf n/s repair:
49963502308_6bd92e2b97_b.jpg2020-06-02_06-30-15 by Mike Jackson, on Flickr
Offside more rotten:
49964288167_a889c25f14_b.jpg2020-06-02_06-30-32 by Mike Jackson, on Flickr
Chopped rotten end off and rolled it over some sheet steel to make this:
49963504678_1ccc039f55_b.jpg2020-06-02_06-31-04 by Mike Jackson, on Flickr
Old and new:
49964006601_3e8659ab56_b.jpg2020-06-02_06-31-20 by Mike Jackson, on Flickr
Welded in:
49964294722_77ac4b8265_b.jpg2020-06-02_06-32-38 by Mike Jackson, on Flickr
Back to this old chestnut. The massive difference between inner wing profiles of the Heritage panel and the original A post:
49963507298_dd65136dd9_b.jpg2020-06-02_06-31-50 by Mike Jackson, on Flickr
Getting some spot welds in:
49963507953_0ac2c7cd13_b.jpg2020-06-02_06-32-06 by Mike Jackson, on Flickr
Welded some threaded bar to the framework to pull the flitch panel inwards and close up to the parcel shelf:
49964293917_2a16109e70_b.jpg2020-06-02_06-32-23 by Mike Jackson, on Flickr
Got the shell level; taken across the rear window apertures:
49964011456_9f3a31ebcd_b.jpg2020-06-02_06-32-51 by Mike Jackson, on Flickr
Success! Bulkhead crossmember also level:
49964012811_51e45b6c60_b.jpg2020-06-02_06-33-14 by Mike Jackson, on Flickr
Tidyup and rest:
49964297547_11e7c93b72_b.jpg2020-06-02_06-33-27 by Mike Jackson, on Flickr
#129 minimikej
minimikej
  • 347 posts
Posted 03 June 2020 - 05:59 PM
Weather been too awful to do much today, but I've located the n/s door and offered it up.
Gaps are good on the front rail:
49967149508_a2df991925_b.jpg2020-06-03_06-42-45 by Mike Jackson, on Flickr
And the top rail:
49967150173_515668e55b_b.jpg2020-06-03_06-43-01 by Mike Jackson, on Flickr
And the rear edge:
49967929437_59651ce6b7_b.jpg2020-06-03_06-43-12 by Mike Jackson, on Flickr
But zero gap on the front edge! Here you can just about make out the remains of the original A post:
49967151763_70ff9fed9e_b.jpg2020-06-03_06-43-34 by Mike Jackson, on Flickr
Both doors have always been wedged in their frames under my ownership. Paint worn off along the entire rear edges of both doors. Can't understand why though; the A posts do not look like they have been repaired in the past. Anyway, onto the next issue.
I mentioned previously the poor fit of the Heritage n/s inner wing. Had the exact same issues on my previous mk1 project (see here: http://www.theminifo...-rebuild/page-7)
Tried to get some measurements to demonstrate, to discount any alignment issues on my behalf.
Here is the eyeball measurement between the shoulder pressed into the inner wing, the shiny horizontal line at the top of the tape measure in the photo, and the top dimple where the inner A panel would nestle up:
49967153453_a45ac840e5_b.jpg2020-06-03_06-44-18 by Mike Jackson, on Flickr
5 Inches, give or take.
Now compare to the o/s Heritage inner wing:
49967153963_a099299023_b.jpg2020-06-03_06-44-31 by Mike Jackson, on Flickr
4 inches!
Ties up with the awful profile at the top.
I can't be the only one experiencing this problem, what do other people do please? I'm minded to cut the edge right off, shift it upwards, and re-weld it!
Edited by minimikej, 03 June 2020 - 06:08 PM.
#130 Homersimpson
Homersimpson
  • 829 posts
Posted 03 June 2020 - 06:25 PM
Being level like that is almost certainly better than when it was made :-)
#131 minimikej
minimikej
  • 347 posts
Posted 05 June 2020 - 06:33 PM
Time to start on the A posts. First job, getting the sheared studs out of the door hinges. 3 out of 4 came out.
49974366296_7d27533fd9_b.jpg2020-06-05_07-14-07 by Mike Jackson, on Flickr
Mock up the outer A panel and wing. I used joiners biscuits to provide a uniform 5mm gap aroud the door:
49973847333_35ec04fc46_b.jpg2020-06-05_07-14-21 by Mike Jackson, on Flickr
Then the fun starts. It's a 4 dimensional problem. Everything has to be replaced in the A post assembly but you can't do it all at once or the gaps will be awful. As I learned on the last project.
So, start with what's most visible, outer A panel. Tacked in place, but only temporarily to enable the box section of the A post to be assembled in the right place:
49973848678_db72bd5315_b.jpg2020-06-05_07-14-51 by Mike Jackson, on Flickr
With door clamped and spaced with the biscuits:
49974368846_81d92f515e_b.jpg2020-06-05_07-15-03 by Mike Jackson, on Flickr
Next I chopped out the rusty part of the A post that would house the courtesy light switch if fitted, and squeezed in the new one...
49973849998_9869c92756_b.jpg2020-06-05_07-15-13 by Mike Jackson, on Flickr
...and tacked that in place too:
49973851808_32e8625c96_b.jpg2020-06-05_07-15-43 by Mike Jackson, on Flickr
The next job will be to slice out the badly pressed section of the inner wing, attach it to the inner A panel with tech screws, and refit both as a pair to the outer A panel and clamp tight through the hinge bolt holes. And then tack the cutting into its new location. This will hopefully ensure a snug mating between the outer and inner A panels and avoid the nightmare I created for myself on the blue mk1.
Quick look at the door, doesn't look too bad at first glance:
49973852438_15950bba5e_b.jpg2020-06-05_07-15-54 by Mike Jackson, on Flickr
However, there's a really sharp dent / crease on the inside. This is repeated down the n/s rear quarter too:
49973853248_982a79af57_b.jpg2020-06-05_07-16-07 by Mike Jackson, on Flickr
Here you can see where the door was catching in the frame after whatever previous repairs were done in this area:
49974632852_da607b4fe6_b.jpg2020-06-05_07-16-18 by Mike Jackson, on Flickr
49973854193_54a74eb18f_b.jpg2020-06-05_07-16-27 by Mike Jackson, on Flickr
Edited by minimikej, 05 June 2020 - 06:47 PM.
#132 minimikej
minimikej
  • 347 posts
Posted 07 June 2020 - 09:10 PM
Plan into action then. First, cut out the poor A panel mount section:
49982075961_d17b0370f9_b.jpg2020-06-07_09-56-04 by Mike Jackson, on Flickr
Then, seat it nicely against the inner A panel and secure in place with a tech screw:
49982083231_4319b84eb8_b.jpg2020-06-07_10-02-30 by Mike Jackson, on Flickr
49982083686_c8b2a49e23_b.jpg2020-06-07_10-02-39 by Mike Jackson, on Flickr
Then, offer it up to the outer A panel, and clamp in place with all the holes lined up and that
49981561238_314e727447_b.jpg2020-06-07_10-02-49 by Mike Jackson, on Flickr
Tack it in place with some very wide tacks :)
49981561728_b0ea5b1f1c_b.jpg2020-06-07_10-02-58 by Mike Jackson, on Flickr
And finally the reveal - seems to sit flush with the lower A post panel now. Going to have to let in a fillet though to weld it properly unfortunately.
49982085166_96407005e8_b.jpg2020-06-07_10-03-07 by Mike Jackson, on Flickr
Money shot:
49982333032_517c15cbd7_b.jpg2020-06-07_09-58-20 by Mike Jackson, on Flickr
#133 Standeman
Standeman
    Starting My Mini Up
  • Just Joined
  • 2 posts
Posted 10 June 2020 - 04:38 PM
Really great stuff there minimike.....loving the detail. Really helping me visualize whats coming up for mine in the next few months - Thanks! Looking forward to the progress!!
#134 g111mds
g111mds
  • 432 posts
Posted 10 June 2020 - 05:44 PM
Really great progress,
#135 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 11 June 2020 - 10:10 AM
Great work going on! Love that you are making the effort to correct all the little panel issues! ??
