Mk1 Austin Countryman
156 replies to this topic
#31 minimikej
minimikej
  • 347 posts
Posted 14 July 2018 - 03:02 PM
Did some more bracing to connect the front and rear cradles. Then got the angle grinder out.
Are these sills fitted to the wrong sides?
42687362744_719cc98499_k.jpgDSC_0051 by Mike Jackson, on Flickr
Old stick welding rod
42687361174_cc1c6bdf4d_b.jpgDSC_0052 by Mike Jackson, on Flickr
42687359564_1c7c9847c8_b.jpgDSC_0053 by Mike Jackson, on Flickr
43355906102_91ca57a0c9_b.jpgDSC_0054 by Mike Jackson, on Flickr
43355905062_43c3944140_b.jpgDSC_0055 by Mike Jackson, on Flickr
43355891692_9c089c31f3_b.jpgDSC_0062 by Mike Jackson, on Flickr
And off it comes.
41595738340_9989b0d1f3_b.jpgDSC_0064 by Mike Jackson, on Flickr
43355884392_89db0fe5d7_b.jpgDSC_0065 by Mike Jackson, on Flickr
29533379228_54c3d52fef_b.jpgDSC_0066 by Mike Jackson, on Flickr
43403736251_c98bec5ce4_b.jpgDSC_0069 by Mike Jackson, on Flickr
42499599485_74cc92cb6e_b.jpgDSC_0070 by Mike Jackson, on Flickr
43355866812_596043d07b_b.jpgDSC_0073 by Mike Jackson, on Flickr
29533359558_55939fc82f_b.jpgDSC_0075 by Mike Jackson, on Flickr
Edited by minimikej, 14 July 2018 - 03:03 PM.
#32 timmy850
timmy850
  • 3,318 posts
  • Local Club: MITG
Posted 15 July 2018 - 12:15 AM
I think the other switch is for the “parcel shelf” lights. It looked like you had the extra bulbs fitted, they light up the two yellow/clear circles on the bottom of the binnacle
#33 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 16 July 2018 - 05:32 AM
Nice work, you going for a M Machine complete floor to sort that out?
#34 Bat
Bat
  • 903 posts
Posted 16 July 2018 - 07:23 AM
Hi,
Yes those sills are on the wrong sides. The square hole should line up with the box section that goes across the floor by the door step.
Cheers  :proud:
#35 Homersimpson
Homersimpson
  • 829 posts
Posted 16 July 2018 - 06:22 PM
I think vans pickups and estates had the jacking point further back to allow for the potential load in the back.
#36 minimikej
minimikej
  • 347 posts
Posted 16 July 2018 - 07:21 PM
Yes, no question in my mind. I'm debating replacing the front toe-board also. On the one of the pictures you can see from the outside the weld line where the repair pans were dropped in. Not sure what I'll find when I peel them back...
#37 minimissions
minimissions
  • 3,427 posts
Posted 17 July 2018 - 05:43 AM
Both those new panels would sort the underside out that's for sure...the toe boards aren't to hard to fit we did one on my brothers pup a few years back.
#38 minimikej
minimikej
  • 347 posts
Posted 20 July 2018 - 10:01 PM
End of term party for the children round ours. All the mums having a natter, so...
... removed the rear heel board.
28647346807_760db380b4_b.jpg2018-07-20_09-27-13 by Mike Jackson, on Flickr
Old n/s wheel arch tub repairs
28647345577_4a4d208a2b_b.jpg2018-07-20_09-27-02 by Mike Jackson, on Flickr
Sad to say this area is worse than I'd hoped. Still shiny paint on the other side.
42629938275_1d58b28320_b.jpg2018-07-20_09-26-49 by Mike Jackson, on Flickr
28647340057_ce7d5be872_b.jpg2018-07-20_09-26-38 by Mike Jackson, on Flickr
n/s rear subframe mount
42817429714_60b2500f60_b.jpg2018-07-20_09-26-07 by Mike Jackson, on Flickr
Old Stick weld repairs:
43534825411_faccdb6a41_b.jpg2018-07-20_09-25-46 by Mike Jackson, on Flickr
43534814781_ce9eda00e1_b.jpg2018-07-20_09-25-35 by Mike Jackson, on Flickr
Stirrups.
28647312457_d8a6b1439d_b.jpg2018-07-20_09-25-23 by Mike Jackson, on Flickr
#39 Bat
Bat
  • 903 posts
Posted 21 July 2018 - 07:02 AM
Hi,
It's certainly keeping you busy!
Soon they'll only be the roof left  >_<
I've been through it all years ago with mine, at least yours has been left alone. Mine had been badly bodged many times as well!
Cheers  :proud:
#40 minitravellerman
minitravellerman
  • 99 posts
  • Local Club: Minis In Northern Ireland
Posted 27 July 2018 - 09:31 AM
Glad to see another Mk1 woodie being restored. I'm in the final stages of getting mine ready for the road.
Looking forward to seeing your project progress.
#41 minimikej
minimikej
  • 347 posts
Posted 28 July 2018 - 01:28 PM
Does anybody know of a repair section for this please? It's the front edge of the boot floor where it meets the heel board.
42629938275_1d58b28320_z.jpg2018-07-20_09-26-49 by Mike Jackson, on Flickr
Better still would be a full boot floor, but they've not been available for years.
#42 Bat
Bat
  • 903 posts
Posted 28 July 2018 - 04:33 PM
Hi,
Could M machine knock you one up?
If they make heel boards they could use that as a template if you tell them the height and how far back you need it to go?
Cheers :proud:
#43 minimikej
minimikej
  • 347 posts
Posted 07 October 2018 - 03:55 PM
Think I'm going to have to repair the front edge of the boot floor first.
The area between the rear wheel arch and the heel-board  is just patches and filler, can anyone show me what this area is supposed to look like? Is it the same filler panel as for the saloon?
31284819378_2bee5dc87c_z.jpg2018-10-07_04-43-15 by Mike Jackson, on Flickr
30220127337_15d3615c31_z.jpg2018-10-07_04-43-04 by Mike Jackson, on Flickr
44436811614_5d9ed33652_z.jpg2018-10-07_04-42-47 by Mike Jackson, on Flickr
I decided to fold up a repair / replacement for the boot floor leading edge. Had to do this in two parts as the folder isn't wide enough.
44246980675_a1570ed39f_z.jpg2018-10-07_04-42-34 by Mike Jackson, on Flickr
44436796504_bec8d5f384_z.jpg2018-10-07_04-42-09 by Mike Jackson, on Flickr
I'll fabricate the 'lay-by' profile in situ.
Major panels ordered, hoping to make some progress soon.
Edited by minimikej, 07 October 2018 - 03:56 PM.
#44 minimissions
minimissions
  • 3,427 posts
Posted 10 October 2018 - 05:53 AM
Wow you didn't hang around with that grinder did you haha
Nice work Mike.
#45 minimikej
minimikej
  • 347 posts
Posted 14 October 2018 - 05:03 PM
Welded the two half-repairs together:
45268505892_fcb36d8ccf_b.jpg2018-10-14_05-56-34 by Mike Jackson, on Flickr
The decided to attack the toe-board:
44404878695_13914f9c92_b.jpg2018-10-14_05-55-09 by Mike Jackson, on Flickr
Unfortunately the joining edge looks pretty ropey. Will have to let in some new metal along this length.
43502067140_deb3a2c2f0_b.jpg2018-10-14_05-56-16 by Mike Jackson, on Flickr
43502038810_fcc6ba37aa_b.jpg2018-10-14_05-55-37 by Mike Jackson, on Flickr
