Hi all,
as the title suggests I have a newly painted rim and a brand new tyre that have been together for a couple of years but one tyre wont hold air.
What can I use to re seal the tyre to the rim??
thanks,
Graham
Posted 31 May 2018 - 04:07 PM
Hi all,
thanks,
Graham
Posted 31 May 2018 - 04:17 PM
tyre bead seal/sealer
but worth checking where your losing air from first
Posted 31 May 2018 - 05:39 PM
I wouldn't want to use anything on a fresh tyre and rim, I would only maybe use sealer on a damaged or pitted rim if necessary. Are you sure it's leaking from the bead or could it be from the valve?
I would be popping the tyre off the bead, checking it's all clean and re-mounting with plenty of lube to ensure the tyre seats on the bead fully, and stick a new valve in whilst you're there.
