Mini Van Full Restoration
571 replies to this topic
#406 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 09 January 2020 - 03:08 PM
Hi from another LWB Commercial mini owner! ;)
Lovely resto man. Subscribed :)
#407 REVVIT
REVVIT
  • 341 posts
Posted 09 January 2020 - 09:37 PM
HI REVVIT random question.
It this a stengthening plate for solid sub-frame bushes? If so, what did you use / any tips to recreating it?
https://www.amazon.c...y10yyjyLnvskQyi
thanks
Chris
Hi ...no trouble they are just the standard rear subframe mounts remade in stainless..very easy to make providing you can cut and drill the stainless as its hard and eats drills...failing that they are available to buy ready made from a few mini specialists..I do have a spare set if they are any good to you..Cheers..Mark.
#408 REVVIT
REVVIT
  • 341 posts
Thanks welcome to the Resto journey ...
#409 REVVIT
REVVIT
  • 341 posts
Posted 09 January 2020 - 10:30 PM
A bit on the side to FINish the day on...
49358256098_a6494b65a7_k.jpgUntitled by
#410 mattmiglia
mattmiglia
  • 515 posts
Posted 09 January 2020 - 11:21 PM
Which fins did you go for in the end mate?
#411 CBJ805T
CBJ805T
  • 438 posts
Posted 10 January 2020 - 04:09 PM
thanks
Chris
Ah, sorry Mark, I meant, have you welded a strengthening plate to the Toeboard?
thanks Chris
#412 REVVIT
REVVIT
  • 341 posts
Posted 10 January 2020 - 04:41 PM
thanks
Chris
thanks Chris
Arrhhh yes I made the plates bigger out of 2mm stainless ..again easy to do ..drilled for plug welding and holes drilled to accept the standard footprint for the rear subframe mounts.i can measure if you need a reference of size..
#413 REVVIT
REVVIT
  • 341 posts
Posted 10 January 2020 - 04:49 PM
Tried to find a genuine set but no joy and I need them to carry on ..so went for these from minispares ..nicely made and lighter and will do the job of collecting brake dust !
#414 REVVIT
REVVIT
  • 341 posts
Posted 13 January 2020 - 04:43 PM
Needed to sort out my interior mirror ..fancied doing something lower dash mounted as some early 60's car have ..E Type as an example..I also like split screens..so came up with this..
49375235946_b097783a92_k.jpgUntitled by
49375441572_70e3e33122_k.jpgUntitled by
#415 KTS
KTS
  • 2,420 posts
Posted 13 January 2020 - 04:51 PM
another nice touch !
..but won't the furry dice get in the way of the speedo ?
#416 REVVIT
REVVIT
  • 341 posts
Posted 13 January 2020 - 04:56 PM
Ha Ha ..very true at least they will clean the glass !....that is when I get a speedo as I don't have one yet !
#417 mattmiglia
mattmiglia
  • 515 posts
Posted 13 January 2020 - 09:15 PM
Aha the big mirror reveal...love this and looks even better in real life!
#418 CBJ805T
CBJ805T
  • 438 posts
Posted 14 January 2020 - 12:19 PM
thanks
Chris
thanks Chris
Hi Mark,
Thanks for would be useful - what gauge did you use for the welded plate 0.9, 1.2mm.....?
thanks
Chris
#419 REVVIT
REVVIT
  • 341 posts
Posted 16 January 2020 - 09:22 PM
thanks
Chris
thanks Chris
Hi Mark,
thanks
Chris
Sent you a PM  :-)
#420 REVVIT
REVVIT
  • 341 posts
Posted 18 January 2020 - 07:06 PM
Tackled the dreaded arch trim today...was expecting it to be a bit of pain with it being cold out..but turned out well ..
49404048853_c772e8787e_k.jpgUntitled by
49404527231_db20e31900_k.jpgUntitled by
