Wow yes! This looks awesome!
Mini Van Full Restoration
#346
Posted 06 November 2019 - 06:57 AM
#347
Posted 06 November 2019 - 01:23 PM
Looking forward to the rebuild process and in what order...
Me to..will start running fuel and brake lines..followed by the steering rack / pedal box then column..i will then start on subframes and associated suspension/brakes..etc..i might fit the odd pretty bit along the way just for a treat then eventually fit the engine and continue with all ancillaries around it..wiring then follow with fuel tank lights interior etc..sounds simple but no doubt issues will arise..
#348
Posted 06 November 2019 - 07:15 PM
But before any of that i need to fit this ....
Untitled by
in the back of this with 15mm to spare between wheel tubs..!
Untitled by
#349
Posted 06 November 2019 - 07:33 PM
...stick it on a roof rack !!
#350
Posted 06 November 2019 - 08:17 PM
lovelly work mate id hire a trailer if I were you
Edited by mercenary62, 07 November 2019 - 04:14 PM.
#351
Posted 06 November 2019 - 09:10 PM
Theres an idea..i just don't have a MK3 cortina to stick it on to complete the scene...
#352
Posted 06 November 2019 - 09:23 PM
lovelly work mate id hire a trailer if I were you ,15mm gap at each side I wouldn't risk it
Thanks..crazy thing is i do have use of a trailer from work which i originally delivered the van with ..weather forecast is also iffy here on friday so the van idea seemed the way to go..i will make sure its tied down well and has plenty of padding..i will be driving so can take it easy on the 10 mile journey home..
#353
Posted 07 November 2019 - 10:02 AM
Looks amazing mate, good luck on the transport home and rebuild side. bring on the twitchyasses on trying not to damage the fresh paint
#354
Posted 07 November 2019 - 05:32 PM
Cheers....hopefully collection should be ok..ive got plenty of foam to pad any vulnerable areas..once its in the van it should stay pretty stable as i will anchor it to the floor and commence clenching mode on the way home
#356
Posted 08 November 2019 - 09:22 PM
looking forward to what happens next
#357
Posted 10 November 2019 - 04:27 PM
Plenty of room..
#359
Posted 18 November 2019 - 06:58 AM
This is already looking awesome, the more you bolt on the more you see how its going to look. Nice work
#360
Posted 18 November 2019 - 05:19 PM
Thanks @minimissions i will make sure the rest of the build stays at this standard ..i have a few unusual bits to fit yet so these should make it a tad different to the norm..
