Hub Puller
9 replies to this topic
#1 cjdillonnz
cjdillonnz
  • 67 posts
Posted 26 May 2018 - 03:52 AM
Hi. I need to remove the rear hub but I’m unsure of what size hub puller I need. My local auto store stocks a 75mm,100mm and 150mm. What size do you think I would need? Thanks
#2 Spider
  • 14,600 posts
Posted 26 May 2018 - 05:02 AM
None normally, even if stuck, you won't need a hub puller but a bearing separator, as if the bearing is in a very bad way, the inner race maybe seized to the stub axle.
Be aware too the the Left Hand Rear Hub Stub Axle has (or should have) and Left Hand thread on it, so it will undo the 'wrong' way.
#3 cjdillonnz
cjdillonnz
  • 67 posts
Posted 26 May 2018 - 05:45 AM
Thanks moke. Not sure about a bearing separator. All I know is I need the hub off to replace the bearings and races.
#4 Bat
Bat
  • 903 posts
Posted 26 May 2018 - 06:49 AM
Hi,
Try this, once it's striped down bolt the wheel back on and give it a pull and rock about and it should come off.
If the inner race is stuck on the shaft afterwards grind it down in one area until really thin then split it with a hammer and chisel.
If you do it right you won't mark the shaft.
Cheers  :proud:
#5 jamesquintin
jamesquintin
  • 1,017 posts
Posted 26 May 2018 - 07:18 AM
Is there any way of getting the inner race off without cutting...?
#6 Spider
  • 14,600 posts
Posted 26 May 2018 - 07:41 AM
Bearing Separator (though this one is a bit over the top);-
You can use a grinder, but after a mate's effort only last week, I'd recommend against it - he's now looking for 2 rear trailing arms after nicking the seal bosses on both of them - easy to do,,,,
#7 mini13
mini13
  • 3,810 posts
Posted 26 May 2018 - 07:45 AM
Most of the time they Come off with no problems though.
#8 Bat
Bat
  • 903 posts
Posted 26 May 2018 - 08:33 AM
Hi,
Obviously the right tool for the job is the best way, but as pointed out above it's rare that they get stuck.
So it may not be a tool you get much use from unless rebuilding gearboxes...
Cheers  :proud:
#9 jamesquintin
jamesquintin
  • 1,017 posts
Posted 26 May 2018 - 08:36 AM
Cool, i'm going to get some heat on it and see if I can leverage it off...
#10 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 26 May 2018 - 11:11 AM
I have in the past bolted the drum back on the wrong way and tapped it off with a soft hammer but mostly they come off by hand.
