Powerspark Or Accuspark?distributor Identification?
Posted 20 May 2018 - 09:52 AM
Seen two on eBay at around the same price, the accuspark and powerspark. Has anyone experience with either kit?
What's the easiest way of identifying the distributor fitted to my engine?
Posted 20 May 2018 - 11:33 AM
Posted 24 May 2018 - 01:50 PM
I fitted the powerspark kit. It took minutes to fit and worked great first time. Never had any issues with it.
There's a guide to identify your distributor on their website https://blog.simonbb...tributor/#lucas
Posted 24 May 2018 - 04:58 PM
I've used Accuspark distributors on a Land Rover and a Morris Minor - no problems whatsoever with either.
Posted 24 May 2018 - 05:19 PM
Plus 1 for the Powerspark kit. I got the complete replacement distributor and coil. Now I can easily go back to original if I want to.
Easy install, car started first time. Just make sure you use the correct coil and get the wiring right.
Paul
Edited by paul748, 24 May 2018 - 05:21 PM.
Posted 24 May 2018 - 06:09 PM
Posted 24 May 2018 - 07:49 PM
Just be careful what coil you use with them, they all have a minimum coil resistance they can be used with.
Also, use a quality coil, I used one with a Lucas Coil a few years back, the coil dies in about 10 days and took out the module with it.
Posted 27 May 2018 - 04:53 PM
I read something similar a while ago and for this reason I bought the coil and distributor as a kit from Powerspark.
If something goes wrong I hope to get some support.
Posted 27 May 2018 - 06:58 PM
Posted 28 May 2018 - 10:21 AM
Posted 28 May 2018 - 10:31 AM
i wouldn't buy a powerspark dizzy curve was awful on my mg metro engine and they couldn't tell me the curve thro the revs sent it back after hassle. may be better on basic 998 even then I would get the curve checked as could still be losing low down grunt
Don't think the OP is talking about replacing the distributor. And of course replacing the points with an electronic module will have no effect on the advance curve.
Edited by Swift_General, 28 May 2018 - 10:33 AM.
Posted 28 May 2018 - 11:01 AM
just saying in general about the powerspark dizzy 're curve
Don't think the OP is talking about replacing the distributor. And of course replacing the points with an electronic module will have no effect on the advance curve.i wouldn't buy a powerspark dizzy curve was awful on my mg metro engine and they couldn't tell me the curve thro the revs sent it back after hassle. may be better on basic 998 even then I would get the curve checked as could still be losing low down grunt
Posted 10 June 2018 - 09:29 PM
I'm using a Lucas coil tho so some comments have now got me worried, it's within the resistance values advised so fingers crossed it will be ok.
Now have a carb issue come up which has royally pissed me off, the pick up was originally my late dad's, wanted to drive it to the cemetery to him on fathers day but it obviously has other ideas.
