Electronic Ignition. Spark But Not Starting
Best Answer cal844 , 20 May 2018 - 06:38 PM
Fixed!
Timing was just miles out, loosened the distributor and turned it about 1/4 anti clockwise (im sure theres a more technical way of explaining that) and it fired straight up.
so next time I visit someone with a strobe light Ill get it timed up properly but it starts and runs again!
Now we have a coolant leak 😭
You don't actually need a timing light, my dad hasn't used one in 30 years of tinkering and building cars.
Simply mark the dizzy and block(used as a reference for when you need to adjust)
Loosen the dizzy clamp bolt(s) just enough so you can make small adjustments.
Start engine and set idle to 2000 rpm, disconnect and block vacuum advance pipe.
Make adjustment listening to engine for pinking and also a lift in RPM, the engine rpm should rise and fall, you want to go for max rpm then retard a small amount (1/2°) tighten clamp bolt once your happy.
Reset idle(if you used the fast idle adjust screw)
Kill engine.
Connect vac advance then start the engine, it should start straight away and rev up cleanly. Double check everything is connected and tight
Road test.(drive the same route in the same direction, ideally you want to get upto 60/70 mph, it shouldnt misfire, or feel held back during the rev range.)
Sounds alot but we can get a car spot on within an hour Go to the full post
7 replies to this topic
#1 TheFabMini
TheFabMini
  • 459 posts
Posted 19 May 2018 - 06:49 PM
Hi all
Decided to fit an accuspark electronic ignition. Followed the steps and all seemed simple enough. Turned the key and it just spins over and over
I thought Id done something wrong and wasnt getting spark so I took a plug out and spun the engine over and surprisingly saw a nice strong looking spark jumping across...
But we have no life!
Engine was running pretty good on points and condenser, what have I fudged up now!
#2 hhhh
hhhh
  • 422 posts
Posted 19 May 2018 - 07:00 PM
The most obvious thing would be the timing is out. Any chance you swapped wires or got it 180 degrees out?
#3 TheFabMini
TheFabMini
  • 459 posts
Posted 19 May 2018 - 07:12 PM
Ht leads are numbered and the cap only happily goes on 1 way.... how else could I have messed up and got it wrong way??
I dont have a timing light so is there a cheat way of doing it
#4 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 19 May 2018 - 08:00 PM
I bought and fitted Accuspark Electronic Ignition! did have to tweak the timing
a bit to get it running properly, now gone back to points as the accuspark lasted
350mls and gave up, had to get recovered home. Cheapo/crapo IMHO
At least with points its easy to fix roadside, having said that back in the day we
ran Piranha electronic ign in both road and race mini with no problems.
#5 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 19 May 2018 - 09:54 PM
Did you remove the distributor from the engine? Its possible you could have installed the rotor 180 degrees out from where it was
Some info here
http://www.theminifo...3-firing-order/
#6 TheFabMini
TheFabMini
  • 459 posts
Posted 20 May 2018 - 07:03 AM
Some info here
Distributor was left in hoping to avoid any problems... Ill have a read up and see if it helps
#7 TheFabMini
TheFabMini
  • 459 posts
Posted 20 May 2018 - 11:48 AM
Fixed!
Edited by ChrisRuffell, 20 May 2018 - 04:02 PM.
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 20 May 2018 - 06:38 PM   Best Answer
Fixed!
Kill engine.
Edited by cal844, 20 May 2018 - 06:40 PM.
