Are Gaz Shocks That Harsh? (My Bum!)
6 replies to this topic
#1 thebluepotato
thebluepotato
  • 80 posts
  • Local Club: Atlanta Classic Minis
Posted 07 May 2018 - 07:29 PM
Have an all new setup on my Mk4....hi-los with new standard rubber cones.  Using GAZ adjustable (lowered versions) and when I hit very small imperfections in the road, it is VERY harsh on the rear.  I have my GAZ's on the rear turned to the lowest/softest possible setting....front is just 3-5 clicks above lowest setting.
Are GAZ's shocks normally this harsh for normal road use?
Would anyone recommend Protech over the GAZ - and can you get the PT's on very soft setting?
Interested to hear more :shifty:
#2 racingbob
racingbob
  • 3,061 posts
Posted 07 May 2018 - 07:52 PM
yes protecth are good didn't like gaz took them off
#3 nicklouse
  • 18,574 posts
Posted 07 May 2018 - 08:26 PM
shocks control the speed of the wheel. sounds like you have them adjusted to slow and they may be packing down the cones. also being that low does not help.
#4 Spider
  • 14,836 posts
Posted 07 May 2018 - 08:28 PM
Like Nick, I think you have them set too soft and the suspension is bottoming out all too easy / quickly, especially as it's already quite low now.
Try turning them up by about 1/3 to 1/2.
But (and your probably not going to like this!) if you do want a better ride, raise the car up - even just to try it, you can always lower it again.
#5 thebluepotato
thebluepotato
  • 80 posts
Posted 07 May 2018 - 08:43 PM
Interesting......but the rear design does not have a bumpstop, correct?   The suspension is not bottoming out (like from a rolling dip) - its the small things in the road (like 10mm thick reflector) that transmits LOUDLY on the rear.  Like these things pictured below - when I clip them with my 10" tires/wheels, its like BANG BANG BANG (when I run over a few).  Also with pavement patches (not potholes) are really loud on the rear.  Mind you, I only have a mild suspension upgrade...I am using GAZ lowered shocks and maybe my car sits a tad low, but not sure on how it would change by raising it to "soften" the ride over those small imperfections on the road.  Again, I do not think I am bottoming out....I think that would require me to hit a small dip in the road and when suspension compresses severely and would go BOOM (meaning bottom out)
Edited by thebluepotato, 07 May 2018 - 08:44 PM.
#6 thebluepotato
thebluepotato
  • 80 posts
Posted 07 May 2018 - 08:45 PM
Nick - when you say speed of wheel, you mean the wheel compressing up or down (how fast or slow that happens), right?
#7 Spider
  • 14,836 posts
Posted 08 May 2018 - 01:38 AM
I'm wondering now if the subframe mounts might need attention?
All the same and taking that in to account, I'd suggest after checking the subframe mounts, setting the shocks a bit stiffer. If they are 'too soft' then the shock can't control the suspension movement properly and it will over-shoot (this is part of what Nick was referring to).
The other thing is the shock(s) may have had it and are giving little to no damping at all.
