Best Answer RedRuby , 07 May 2018 - 07:29 PM
Fraser, just had what sounds exactly the same funnily enough also on a 93 SPi. It turned out to be a relay. If you look under the bonnet on the offside inner wing you should see two relays, probably yellow. The one nearest the bulkhead (the back on) is for the headlights and the front one is for the indicators as a quick check swap them over and test your indicators. Mine was pitted contacts inside a quick clean and they worked but I took the precaution of fitting a new one anyway. Hope thats what it is as its an easy fix.
Go to the full post
Posted 07 May 2018 - 06:12 PM
Today I was out for a drive and my indicators stopped working. The relay clicks at double speed but none of the indicators, or interior indicator lights on the dash work. No lights, just lots of clicking.
The hazards still work completely fine. All exterior hazard lights and interior hazard lights on dash (obviously same ones as indicators) work fine at normal speed.
Hazard switch and indicator stalk are both relatively new. Around 1 year old. The hazard switch is an aftermarket toggle one but is up to the job.
I'm hopeless with electrics and would really appreciate some help.
Cheers,
Frazer
Posted 07 May 2018 - 07:10 PM
Posted 07 May 2018 - 07:29 PM Best Answer
Edited by RedRuby, 07 May 2018 - 07:30 PM.
Posted 07 May 2018 - 08:11 PM
Cleaned the relays off now and all good but I'll order a new one just to be safe.
Thanks so much mate, this makes it a lot easier to get to work tomorrow :)
Posted 07 May 2018 - 09:15 PM
Ah Redruby you are a legend! That fixed it. Swapped the relays and the indicators work!!
Your welcome Frazer, glad it was that. Took me a while to find as I thought that one relay was for the headlights and the other for front fog lights as my car originally had them, never gave a thought initially that it would be for the indicators as the switching for the indicators/ hazards normally takes place at the switch...........or so I thought
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
