Wiper Park Switch
3 replies to this topic
#1 Ol timer
Ol timer
  • 329 posts
Posted 04 May 2018 - 09:18 PM
Gday everyone... I seem to be  having an issue with the Wipers on my mini
I have a 1972 Leyland mini 1000
The issue I have is that the wipers DONT park
After a bit of Internet browsing I came across information re the wiper Motor and the Park Switch
So as every good Internet Mechanic does I ordered a new switch. Replaced that, alas still doesn't park
The park switch has 3 terminals , however the wiper motor has 2 wires., am I missing  something?
#2 Ethel
  • 26,058 posts
Posted 04 May 2018 - 11:05 PM
No,
fa2259e63418f772a5e5a9b9f2006f31f266c3f4
The extra terminal (yellow wire) is for 2 speed motors, just ignore it.
Simplest diagram I could find. As you can see, the wipers are always live when the ignition's on (green wires are fused ignition live). There's a supply to the park switch that loops through the dash switch when the wipers are turned off. Switching the wipers on merely bypasses the park switch with another supply to dash switch. The park switch earths through its spring retainer clip, it's important to stop the motor dead, otherwise it can run on enough to clear the ramp on the drive gear that opens the contacts and set off on another lap.
If your blades just stop where they are when you turn 'em off it's the supply to the park switch or a break on that green/brown - wire or dash switch terminals.
#3 Ol timer
Ol timer
  • 329 posts
Posted 08 May 2018 - 07:04 PM
thanks for the reply. will look into the wiring and switch.
Have replaced the switch no change, will look at the dash switch as well as fitting new terminal connector to the Green/Brown wire
Edited by Ol timer, 23 May 2018 - 09:39 AM.
#4 Joe Blogs
Joe Blogs
    Just On Tickover
  • 8 posts
Posted 16 November 2018 - 11:02 AM
Thanks for your replies guys, I now have all the info I need.
