Can someone please put up a picture of the hood fixings that are fixed along the top part of the windscreen frame so I have an idea of what to order,Thanks.
Hood Frame Fixings
Posted 01 May 2018 - 07:40 PM
Posted 02 May 2018 - 07:37 AM
The ones down each side of windscreen will be different depending on the year and model of your Moke. They are all attached using rivets.
Edited by sa mokin, 02 May 2018 - 07:37 AM.
Posted 02 May 2018 - 08:55 AM
As SA has said ^ though, the long ones are the 3rd ones from the ends
Short Types
Long Types
These I've posted up aren't genuine Lift the Dot brand, but are arguably better quality and cheaper.
Posted 07 May 2018 - 03:45 PM
Thanks for the info guys.
Posted 12 January 2021 - 08:25 PM
Is there a set pattern for the position of the fixings on the screen frame? I’m fitting a new frame, should I use the old frame as a pattern for the fixing points. Do I wait until I get a hood before I drill the frame?
Posted 13 January 2021 - 09:48 AM
The trimmers will want all the body hardware fitted when you hand over the Moke for them to do their bit.
I'll put up a drawing tomorrow (our time !), but in the mean time, there is 11 Lit-a-dot posts across the top of the frame, of these, 2 are long and the others all tghe normal short ones. The Long ones are fitted 1 stud in on top, from the ends. These are so that along with the hood, there's also straps that fit to the Posts. The two Straps run from the Windscreen Frame, over the Hood Bows and on to the Rear Panel. Originally, the Straps were screwed to the Hood Bows (Countersunk Self Tapper with Cup Washers) to hold them in the right place, however, I used Pop Rivets as they have a lower Profile.
Posted 15 January 2021 - 06:39 AM
Sorry I'm only getting around to this now.
This is the layout of the Factory Frame for the Australian 1968 - 1979 Windscreen Frames.
Hopefully it makes some sense !
