I finally got around to fitting my reconditioned engine and box to my mk2 cooper, While the motor was out the engine bay, front subframe and everything else has been reconditioned including a new steering rack as the old one was knocking over bumps.
I took the car for a shakedown run that lasted about 20 feet as it sounded like a drive shaft was loose. Many tests and 4 hrs later having checked every conceivable part from drive flanges, calipers, ball joints, lower arm and radius arm pins, rack U bolts, steering column, doughnuts, hi-lows, subframe mounts, engine steady etc etc, I even removed the shocks and then it hit me, my brand new rack was a shi**er.
I popped the brand new QH track rods ends off and the Knocking noise was gone. It appears the ball joints in the rack creak loudly when gently podded with the palm of your hand which transmits through the steering wheel like an earth quake. The ball joints are not the rebuildable type so I cant strip them.
Unfortunately I bought the rack from the Minisport stand at Castle Combe about 4 years ago so bang goes my warranty but the question is am i the only unlucky mug that bought a duff rack or are they all hit and miss made in China these days.
I am reluctant to buy another new rack other than a genuine Rover rack that probably no longer exists and having had 3 duff recon racks in a row supplied by a local Autoparts many years ago i would never try another.
So much for saving time by fitting new parts so I will be using Moke spiders excellent rack refurb guide when I dug out a rebuildable old rack from my spares hoard.
The good news is that the motor goes well :)
