1972 Rhd Daily Driven 5Pw Promotive Build In The Usa.
85 replies to this topic
#76 evolone38
evolone38
  • 72 posts
Posted 23 January 2019 - 11:30 PM
@ evolone38
I know what you mean ... winter months are here!
Where I'm from in Quebec the snow comes early.
Can’t wait to get the mini reliable enough to daily in the summer tho.
By the way your mini is looking great!
Thanks! I have had some fun this summer with it, tribulations aside but I plan to keep it up and go for more in the future.
Winter update: Oregon has had a very mild winter and dry sunny days have been more frequent. I have not worked on it or driven it because of hand surgery but I did get a chance the other day for a light stroll.
The helmet pic is from my day of glory this last summer #memories.
Edited by evolone38, 23 January 2019 - 11:33 PM.
#77 evolone38
evolone38
  • 72 posts
Posted 01 February 2019 - 07:57 PM
https://youtu.be/_eoALHKFLmU
A quick dash shot of the car for your entertainment.
#78 KTS
KTS
  • 2,420 posts
Posted 01 February 2019 - 09:55 PM
you've definitely got a loud pedal fitted in there haven't you ?!?
nice
#79 iSonic
iSonic
  • 34 posts
Posted 14 February 2019 - 10:51 AM
Had CTS surgery done? I have very similar pictures of my hand... Takes a long time to recover fully.
#80 evolone38
evolone38
  • 72 posts
Posted 14 February 2019 - 08:37 PM
nice
I try to keep it quiet, the RC40 exhaust keeps it tame under 6k.....lol
#81 evolone38
evolone38
  • 72 posts
Posted 14 February 2019 - 08:40 PM
Yes, I got cut open and ravaged... it has been 4 months now and I still cannot turn a wrench or grip stuff. Irritating since I ride bikes / motorcycles and build RC cars. i sure do hope it gets ALOT better.
#82 evolone38
evolone38
  • 72 posts
Posted 28 February 2019 - 02:00 AM
I have been doing a little bit of testing. Seems something like this, drops the engine temps by about +20 F degrees without the fan and doing 9k instead of 6k.
Update.. Drove 40 miles in 45F degree weather, hit rev limiter alot and kept it rolling... temps never went above 190F and only to 208 when sitting in traffic with no fan needed. Usually I would be sitting at 220+ at 6k with fan. This lightweight, easy chain access intake panel definitely dropped +30 F off my usual.
Mood: STOKED
Edited by evolone38, 01 March 2019 - 01:44 AM.
#83 evolone38
evolone38
  • 72 posts
Posted 11 April 2019 - 06:08 AM
Well the car has been driving so well it just had to cause me trouble...
The header is now getting Ceramic coated, no more header wrap, it just deteriorated so quickly. Now maybe it will stop frying CV boots all the time being coated and slightly modified for more clearance.
#84 evolone38
evolone38
  • 72 posts
Posted 17 April 2019 - 05:44 AM
So after the blasting/welding session I had it fully Ceramic coated. A hammer was applied on an area that kept fouling my CV boots.
I replaced the ailing boot with a new setup to rebuild this one pictured.
Lost my stator late last year so while it was up on stands I did a stator replacement.
Also I did another change, tapped diff case and threaded for a 4AN fitting for a bigger vent tube that flows more, plus doesn't leak now. The original setup leaked a bit, drove me nuts!
#85 minidave04
minidave04
  • 148 posts
  • Local Club: ashford mini owners club
Posted 17 April 2019 - 07:17 PM
What is the reason for the larger diff tube does it help also stop the leaks
#86 evolone38
evolone38
  • 72 posts
Posted 17 April 2019 - 10:07 PM
Less internal case pressure and a better hose connection. The bottom case hose, facilitates easier draining and filling of diff case remotely, much cleaner and easier interactions with a little more fluid capacity.
