Sykes Pickavant Engine Lift Bracket
Best Answer floormanager , 24 April 2018 - 07:39 PM
Good tip Retroman, thank you.
As above it does help when lifting the engine in and out..
If you jack the back of the car up about a foot too it will clear the bulkhead perfectly
Good tip thank you very much Retoman :D
Go to the full post
5 replies to this topic
#1 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 23 April 2018 - 07:14 PM
Hi all,
I've recent bought one of these engine lift brakets for an engine change (remote box). Aplogies for "borrowing" the photo from ebay but I am wondering if anyone can give me a clue how to use this and what the two different positions on the bracket are for and which one to use.
Thanks,
Paul
  • Attached File  lift.JPG   97.87K   37 downloads
#2 imack
imack
  • 2,382 posts
Posted 23 April 2018 - 08:11 PM
You'll probably need the lower lifting position as this will tip the engine back slightly and help with clearance on the remote diff housing. The top position will give a more upright lift, probably more use for midgets and minor 1000's.
#3 floormanager
floormanager
  • 804 posts
Posted 23 April 2018 - 08:14 PM
That makes sense - thank you.  I was wondering what the upper position was for.  Did not think about Minors!
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 23 April 2018 - 08:15 PM
#5 floormanager
floormanager
  • 804 posts
Posted 24 April 2018 - 07:39 PM   Best Answer
#6 Spider
  • 15,880 posts
Posted 24 April 2018 - 08:14 PM
In the Instructions for original BMC version, they say that lift bracket, while different in appears, I think works a similar way, that it is for transverse engines. The front (lower) position is of course to get an engine tilt for fitting the engine, but the rear 'central' position is for lifting the engine (square) to line up the Drive Shafts;-
They do also say it can be used on in line engines, however, I think in some cars, these too need to be tilted, but not in a way this bracket can sensibly accommodate.
