Suspension Upgrade: Poly Bump Stop
16 replies to this topic
#1 Screwdriver
Screwdriver
  • 281 posts
Posted 16 April 2018 - 04:35 PM
Greetings!
I came across the suggestion to switch to Poly bump stops given their superior geometry. I wonder if such a simple and small change can lead to any noticeable improvement in ride quality. I am currently running on new standard rubber cones and 12 inch wheels running 165/60 R12 Dunlop rubber, but find the ride quality over harsh London roads to be quite...well...harsh.
I will gladly purchase any modifications to improve the ride. My shortlist so far includes:
1) Poly Bump stop (assuming forum feedback is good)
2) KYB Gas-adjust struts
Any other suggestions welcome!
Edited by Screwdriver, 16 April 2018 - 04:38 PM.
#2 nicklouse
  • 18,577 posts
Posted 16 April 2018 - 04:46 PM
They won't really change a thing for general driving as they don't get touched. It is only for extreme end of travel.
Edited by nicklouse, 16 April 2018 - 04:46 PM.
#3 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 16 April 2018 - 04:56 PM
Poly bump stops wont do a thing. If the suspension ever reaches the bump stop you would be better of with rubber ones.
Only advantage is the poly ones would last longer.
Its a min! They tend to have a harsh ride.
#4 Screwdriver
Screwdriver
  • 281 posts
Posted 16 April 2018 - 05:00 PM
I should have clarified that this was for the crash craters on our roads and not daily road imperfections
#5 nicklouse
  • 18,577 posts
Posted 16 April 2018 - 05:14 PM
Still won't do much.
#6 Spider
  • 14,840 posts
Posted 16 April 2018 - 05:46 PM
I wouldn't fit anything Poly, it's too hard and the wrong material.
If you are looking for a better bump stop, that is less harsh, fit these;-
http://www.minispare...px|Back to shop
They are so good in fact that you won't even know you've touched the Bump Stop when they are called in to 'action'.
These fit to the top arm, on the shocker bolt (you'll need to drill the hole bigger in the mounting bracket) and you'll need to remove the existing bump stop of course.
#7 Cooperman
  • 23,276 posts
Posted 16 April 2018 - 07:30 PM
The best way to make a classic Mini more bump-compliant is to do the following:
Fot top-quality rubber spring cones, raise the ride height by around 1/2" all round by using Hi-Los, fir adjustable dampers set fairly soft and put the tyre pressures at no higher than 28 psi all round.
If it is still not sufficiently bump-compliant it would be best to buy a bigger car with large wheels and high-profile tyres (a Land-Rover Discovery is great on such bumps).
#8 Artstu
Artstu
  • 830 posts
Posted 16 April 2018 - 07:48 PM
If you know your stuff and want to fine tune something to suit there is plenty of choice
https://uk.rs-online...-stops/2547652/
#9 Chris M
Chris M
  • 167 posts
Posted 16 April 2018 - 07:57 PM
Sorry to hijack this post but How about changing to coil springs,will this improve the ride?
#10 Artstu
Artstu
  • 830 posts
Posted 16 April 2018 - 08:07 PM
:o you're in trouble now
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 16 April 2018 - 08:13 PM
No
EDIT: Moved to products, questions and technical.
#12 nicklouse
  • 18,577 posts
Posted 16 April 2018 - 09:48 PM
totally unsuitable for a road going Mini in any shape or form.
#13 Magic jason
Magic jason
  • 522 posts
Posted 16 April 2018 - 10:17 PM
Clearly your mini isn't low enough if you have bump stops  :lol:
Maybe new seats?  :whistling:
#14 timmy850
timmy850
  • 3,328 posts
  • Local Club: MITG
Posted 17 April 2018 - 12:22 AM
So these can be fitted to dry cars too with the small modification to the bracket? I had been wondering about them
#15 Spider
  • 14,840 posts
Posted 17 April 2018 - 07:47 AM
Yes.
