Hif38 Overflowing
Posted 14 April 2018 - 11:37 PM
set up is 988 engine, hif 38 carb, electric su pump at rear, plastic inline filter under bonnet plus running the gause filter in the carb too... baffled
Posted 14 April 2018 - 11:39 PM
did you set the float height correctly?
Posted 15 April 2018 - 07:23 AM
i set the float according to a you tube video i found, using a ruler across bottom of carb housing?
ive had the float submerged in water to see if its got a hole in it and therefore takes in petrol but it checks out ok.
it doesnt overflow straight away, usually after 5 or so mins of running,
would the engine breather cause this, would it run ok without the breather attatched?
Posted 15 April 2018 - 08:31 AM
Could the pump be faulty?
Still most likely to be the float or valve. The float can wear on the pivot shaft causing it to stick. Is there a a sealing washer under the valve?
Posted 15 April 2018 - 09:30 AM
everything seems ok with the pivot .
Posted 15 April 2018 - 10:10 AM
Sorry,
Looks like Hif's have a taper fit rather than a washer. Might still be worth looking at potential leaking around the valve threads etc.
Posted 15 April 2018 - 11:09 AM
just been to try the carb again on the mini and do further investigations and its still doing the same thing.
i dont think its the fuel pump, you can see each pump of the fuel into the plastic inline filter and its only just keeping the bottom 1/4 of the filter full.
the fuel starts to seep out of the overflow for probably 30 seconds and then builds up to a full spurt.
stripping the carb again to check things....
one thing i did try was turning the carb upside down and blowing in the feed pipe, the float valve is defo shutting as i couldnt blow air in .
on a positive note my wiring loom conversion i made to put the pup back to a single centre clock all works 😊
Posted 15 April 2018 - 01:04 PM
A new float valve should not be the issue, assuming its not cross-threaded and tight
Whats the electric pump?
An Su carb only needs low pressure
Posted 15 April 2018 - 02:01 PM
Posted 15 April 2018 - 02:46 PM
morning
well not knowing if the info on "youtube" is correct try the correct source of info
http://sucarb.co.uk/...tter-reassembly
Posted 15 April 2018 - 03:21 PM
Ok Bit confused, is it the new float valve or 2nd hand..?
And I would check the float level again too...also question the metal tag that closes the valve, I wonder if its weak
You did mention the breather, is the float chamber breather blocked ?
Posted 15 April 2018 - 04:20 PM
after changing to the hif38 and this problem arising i initially thought it was the float valve and changed the valve assembly for the one out of the previous carb as this i had no issues with.
this didnt clear the overflowing problem up so i decided to buy and install a new float valve assembly.
float height has been checked and checked again, even compared it to some other hif carbs i have laying around.
just stripped the carb again, reset float height and checked valve for leaks using some petrol around the needle itself and compressed air down the fuel pipe ( carb upside down on bench) no bubbles whatsoever until releasing the pressure off of the needle valve.
hopefully will finish work at a resonable time and refit the carb and try again.
mrs is now moaning as i stink of petrol haha
Posted 16 April 2018 - 10:22 AM
Modern fuel isn't a nice smell....going back it used to smell good...
My mrs complains about me cooking black crackle paint,
Its not an issue...cooker hood on full bore, window open, stink only takes about 3 hours to go...lol
Posted 17 April 2018 - 09:20 AM
had enough aggro when i was soldering up my dash wiring loom on the kitchen side... women pfffft lol
