Roof Gutter Repair
rust repair
7 replies to this topic
#1 Nossedout
Nossedout
  • 160 posts
Posted 13 April 2018 - 09:52 AM
Hi All,
Currently I am in the process of doing a light restoration a 1972 mk3 mini and it has quite a few rust spots on the roof gutter (the edge itself).
It was repaired a couple of years ago with fiberglass and body filler. after it was painted in oil based paint with a roller -.-' now I have to fix all the work the previous panel beater did.
My question here: what is the best way to do a roof gutter edge? meaning the curved L piece? is it possible to purchase a length (like the drip rail)? or how do  you usually do it?
I have repaired half of a side with 15cm pieces but not satisfied with the work :(
Joseph
#2 Nossedout
Nossedout
  • 160 posts
Posted 13 April 2018 - 09:59 AM
Forgot to mention, the way I repaired it was by first doing a 90degree bend, then hammering the edge on a long 10mm round bar on an anvil.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 13 April 2018 - 10:44 AM
The round bar i used was a lot smaller, if memory serves me correctly i used 6 or 7mm. The biggest issue is the curved line of the roof. For that i would use a shrinker and gently form the curve after you have made the gutter piece. Make sure there is enough material to enable you to use the shrinker.
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 13 April 2018 - 12:14 PM
I bent a piece of bar to shape of corner of roof, then I formed steel plate on this, turned out very good, I also made a forming tools for the holes in corners,
Just take your time
Mk4 onwards then you can replace entire panels to get the gutter but Mk1,2 & 3 the corners are not available as far as I am aware
Edited by Daz1968, 17 April 2018 - 12:13 PM.
#5 CBJ805T
CBJ805T
  • 438 posts
Posted 16 April 2018 - 09:50 PM
Ive got the top of a drivers side rear 1/4 heritage panel Im selling if thats any help?
Chris
Edited by CBJ805T, 16 April 2018 - 09:52 PM.
#6 Nossedout
Nossedout
  • 160 posts
Posted 18 April 2018 - 09:13 AM
Hi,
I ended up repairing mine as stated before...
#7 SamG
SamG
  • 88 posts
Posted 11 May 2018 - 08:55 AM
Anyone have a pictures of this process? I'm also looking to do the exact same on my '72 in the near future, and whilst I'm fairly happy with how you've all done it a picture paints 1000 words!
#8 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 May 2018 - 12:30 PM
Type in Wills Mini Special and have a look at that.
http://www.theminifo... mini special
Also tagged with one or more of these keywords: rust repair
