Speedo Mounting
7 replies to this topic
#1 Shaggy33
Shaggy33
  • 311 posts
Posted 11 April 2018 - 10:33 AM
Quick question guys. I am looking to mount the Smiths Classic Speedo https://www.minispor...eedo-90mph.html
into a flat aftermarket dash, is this possible? I only ask as they appear to have special mounting brackets to suit the centre binnacle instead of the U shape clamp type seen in smaller guages.....
Also can someone confirm the diameter of the aperture required to accept this speedo, I am told theyre 100mm but not sure if thats outer diamter including the chrome bezel or the hole needed to accept the speedo.
#2 Compdoc
Compdoc
  • 612 posts
Posted 11 April 2018 - 11:25 AM
No disrespect to the the huge number of knowledgeable members on here, but I think I would prefer to measure the exact size of the speedo before taking a jigsaw to a new dash. At least then if you make a balls up you've only got yourself to blame. Regarding the speedo mounts, a couple of "L" brackets screwed to the back of the dash adjacent to the the speedo screw holes should do the trick.
#3 nicklouse
  • 19,046 posts
Posted 11 April 2018 - 11:36 AM
 way bigger than 100mm 125 or 130 is more like it but I have no real idea.
#4 Shaggy33
Shaggy33
  • 311 posts
Posted 11 April 2018 - 11:39 AM
thanks compdoc. Appreciate what you are saying re the diameter. As I don't have the gauge in my posession yet I was hoping someone could just tell me wha they've cut theres to per perhaps tell me what the manual says?
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 11 April 2018 - 08:38 PM
My original is 130mm diameter, but as others have said it'd be best to double check.
It fits with 2 bolts, M5 fitted mine. You'll need 2 uprights like what i've done on my fibreglass one, then the screws go through.
#6 Shaggy33
Shaggy33
  • 311 posts
Posted 12 April 2018 - 10:34 PM
Thanks Alex very helpful
#7 mailman
mailman
  • 222 posts
Posted 18 January 2025 - 09:07 PM
Is your Fibreglass binnacle the standard/original outside dimensions?
#8 alex-95
alex-95
  • 6,078 posts
Posted 22 January 2025 - 07:43 PM
Bigger than standard on the front but fits in the same on the back mounting. There some photos in my build thread https://www.theminif...rebuild/page-41
