Milky Mix Under Oil Cap
Best Answer brivinci , 16 April 2018 - 03:06 PM
I piped the rocker covers breather into the rest of the cars breather system and its cured the issue. Makes total sense now. The cap is not vented so the breather HAS to be open to vent. Thanks all.
Go to the full post
Posted 07 April 2018 - 04:55 AM
I did a test the other night. Cleaned the cap and took the car for a 100 mile, highway/motorway drive. Testing a few other things in prep for a long weekend trip. After driving at 70mph whenever not in traffic (about 30mims of it) I got home and checked the cap the next day. More milkyness! Again, oil and coolant look fine.
I know that cars that arent driven regularly or for long distances can build moisture in the motors but could this still be the case? A few months back I replaced all my coolant lines with mini spares silicone SPi kit. What we pump is the best they sell. Thermo is correct SPi type. Cars temp is perfect...and Im checking from both the original gauge and a electronic VDO with temp sensor in the head by thermostat. Oddly, I have noticed a coolant smell in the car while driving. Heater core has now visuals signs of a leak and no smoke. Checked plugs recently and they all looked as they typically do. None have been steam cleaned nor is there clouds of white smoke.
Wondering what you guys think. Have I missed anything? Pix are of after 100 mile trip. Notice the pools of oil around valves. Not white like cap.
Posted 07 April 2018 - 04:58 AM
Posted 07 April 2018 - 07:08 AM
You know you have a mayo problem when you remove the rocker cover and find it entirely full of mayo
Edited by Sprocket, 07 April 2018 - 07:09 AM.
Posted 07 April 2018 - 07:54 AM
I would remove the rocker cover and clean it all out, check the breathers are clear.
Change the oil and filter then keep an eye on oil and coolant levels.
Posted 07 April 2018 - 08:32 AM
What oil do you use as some do it more than others.
I have noticed the Halfords 20w50 oil seems to do it but the Minispares own brand does not.
Posted 07 April 2018 - 09:09 AM
Posted 07 April 2018 - 02:38 PM
Ive been running valvoline VR1 20/50 since last rebuild. Its easy to get here in the states and has the extra ZDDP already in it.
Interesting about the SPis positive crank system. The valve cover is an old alloy finned type. Came on my 66 years ago. It has a built in breather pipe on top. I blocked that off as I had nowhere to route it (although I have plans now for an oil separator) and the cap is strange. Ive had to make a makeshift seal for it as it was missing. The whole thing has bothered me but I love the cover. Maybe Ill switch it out for a standard unit and see.
Posted 07 April 2018 - 03:03 PM
Posted 07 April 2018 - 05:13 PM
Posted 07 April 2018 - 08:52 PM
I'd suggest your makeshift seal is not working properly
It doesn't necessarily have to be cold for this to happen. humid air will give up the moisture when its pressure drops, at the same time the temperature drops. If the filler cap has a small hole in it, this will be the point where the moisture will build up. In this case I suspect your cap doesn't have a small hole, but rather the seal is leaking. With the positive crankcase ventilation working as you cruise along, the engine crankcase is in a partial vacuum, more so if there is no real vent in the filler cap. This is what creates the pressure drop and subsequently causes the moisture build up in that localised area as the air leaks past the seal.
If you look at the original tin cover filler cap, it is vented and contains a compressed wire filter. This cap allows a greater flow of air in or out of the crankcase, prevents a lower than normal crankcase vacuum, thus would normally prevent the build up of Mayo in most driving conditions. If you can fit some sort of gauge to measure crankcase pressures (vacuum in some instances) it might show that you could be pulling a significant vacuum under certain driving conditions.
Would be worthwhile pulling the breather hoses and looking inside those too, the ones from the transfer case, the timing gear case and the large one onto the throttle body.
Posted 08 April 2018 - 08:00 PM
So, if I were to reopen that breather, could I pipe it into the cars ststem? My SPi has that metal pipes that wrap around rhe back of the rocker cover. I could T off one of the pipes and run it all together. Would that work??
Posted 16 April 2018 - 03:06 PM Best Answer
Posted 15 May 2018 - 05:23 AM
