Location Of Air Conditioning Relay
electrical
Best Answer Booska , 15 April 2018 - 09:26 PM
Never was able to ID the correct relay but I did manage to find the culprit; an inline fuse hidden behind stock airbox was a complete disaster (3 pieces). I replaced 4 other inline fuses while I was at it and everything is running fine
Go to the full post
7 replies to this topic
#1 Booska
Booska
  • 10 posts
Posted 06 April 2018 - 09:18 PM
My AC cut out the other day, I believe it's the AC relay, anyone here own a Japanese import that can point me to it or suggest whatever else I should test? I will test the fuses this weekend but want to get a head start if it's the relay (once I find it).
thanks.
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 06 April 2018 - 10:36 PM
If it’s a JDM it will be on the rhs of the steering wheel under the bottom dash cover. Looks the same as the engine MFU - Multi Function Unit aka relay pack. Many are white rather than the black of the engine bay type.
FS
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 07 April 2018 - 04:10 AM
maybe it needs regassing
#4 Booska
Booska
  • 10 posts
Posted 07 April 2018 - 03:07 PM
Had it regassed before I brought it home
Edited by Booska, 12 April 2018 - 07:01 AM.
#5 Booska
Booska
  • 10 posts
Posted 07 April 2018 - 03:08 PM
If its a JDM it will be on the rhs of the steering wheel under the bottom dash cover. Looks the same as the engine MFU - Multi Function Unit aka relay pack. Many are white rather than the black of the engine bay type.
FS
#6 Booska
Booska
  • 10 posts
Posted 07 April 2018 - 03:10 PM
Excellent Ill tear into this afternoon. The next problem will be replacing it, if my sleuthing is correct it seems to be discontinued and hard to find NOS
#7 FlyingScot
FlyingScot
  • 2,664 posts
Posted 07 April 2018 - 04:55 PM
Yes you’re right....but like the engine MFU if you carefully open it with a craft knife you can replace the relays (it have done on engine MFU before cannibalising other ones)
FS
#8 Booska
Booska
  • 10 posts
Posted 15 April 2018 - 09:26 PM   Best Answer
