How To Fit Drip Rails?
6 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 02 April 2018 - 09:46 PM
Got replacement drip rails but they are straight and the roof guttering is curved at the ends, so how do I get round this? Here is an example picture.
Attached File  images.jpeg   7.02K   10 downloads
Edited by HUBBA.HUBBA, 02 April 2018 - 09:47 PM.
#2 Ethel
  • 25,784 posts
Posted 02 April 2018 - 11:12 PM
A couple of ideas:
Clamp the ends in a vice and bend them gradually clamping less of the end.
As you need to shrink the attached side fold, slot it with a hacksaw, then close up the cuts.
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 02 April 2018 - 11:13 PM
Having just done 2 the ones you buy are flat and too wide. So I put the ridge in so they sit upto the gutter and narrowed the lip...
Nothing to do with the front corner....If you have welded it on its a case of bending carefully with a rubber hammer, some heat helps too, but gentle over a length otherwise it will kink.
I did wonder when I did them if it would work better to weld the very front on first then some gentle heat to get the rest back in line.
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 03 April 2018 - 07:17 AM
I just put the ends in the vice and carefully bent them a little at a time with trial fitting to ensure ok,
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 03 April 2018 - 09:18 AM
The thing is cause the profile is at a 45/135 degree crease, thought it won't shrink very well without it increasing down more. Saying that I have seen a lot of fitted rails that point down at the end.
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 03 April 2018 - 09:37 AM
Could be an excuse for me to buy a shrinker stretcher. Fancied one for sometime
#7 Daz1968
Daz1968
  • 2,058 posts
Posted 03 April 2018 - 03:51 PM
Now one of those would make it easy, I could have done with one for my upper side panel repairs as well. But as my project was a one off I fabricated them, superb tool thoughif you are planning more restorations.
