Rear Bump Stops
14 replies to this topic
#1 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 25 March 2018 - 05:05 AM
Hi all, does anyone have any experience of using these rear bump stops?
https://www.7ent.com...ear-for048.html
I'm running 7x13's, slightly lowered, KAD alloy rear arms and camber brackets. I like my set up but my tyres occasionally rub the arches on bumps.
cheers
#2 Steve220
Steve220
  • 4,990 posts
  • Local Club: BMC
Posted 25 March 2018 - 08:01 AM
What are the rest of your rear suspension components like? ie how old are your cones? Do you have the car stupidly low on hi-los? What arches do you have?
#3 Spider
  • 14,638 posts
Posted 25 March 2018 - 08:15 AM
I've not used nor held them in my hands.
Looking at how they fit, I'd suggest they need a sandwich plate inside the boot, the flat & spring washers will only tear holes in the wheel arch eventually.
Have you considered fitting bump stops to your shocks?
This is a pretty basic type, but there's many other available
#4 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 25 March 2018 - 08:26 AM
It's not stupidly low and has sportspack arches.
#5 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 25 March 2018 - 08:30 AM
Are these available for a mini?
Edited by Raggedroy, 25 March 2018 - 08:31 AM.
#6 Spider
  • 14,638 posts
Posted 25 March 2018 - 08:41 AM
They are not Mini Specific, but used on lots of cars, typically as after market.
Take a visit to a Suspension Shop, they should have a few different types you can look at.
#7 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 25 March 2018 - 09:17 AM
That sort of bump stops on the shock will only be an option if you have coilovers won't it?
All the shocks I've seen would need to be taken apart to fit something like that.
#8 nicklouse
  • 18,377 posts
Posted 25 March 2018 - 09:22 AM
most will already have a rubber bump stop and you can get clip on nylon ones to add to it,
#9 Spider
  • 14,638 posts
Posted 25 March 2018 - 10:30 AM
They are one's I've bought locally and fit and they go on any shocker
You do need to remove the useless, rattle,r stone trap dust shield on some shockers or as Nick's suggested, you can get clip on types.
They aren't exclusively used on coil overs, they can be used on any shocker. Here's a 'plain' shock and a different type of bump stop
#10 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 31 March 2018 - 05:56 PM
Would it be possible to run coil over shocks without the springs to make use of the built in bump stops that are fitted to most coil overs?
#11 nicklouse
  • 18,377 posts
Posted 31 March 2018 - 06:41 PM
all shocks have built in bump stops. have a look at yours and you will see it. then some thing like
https://www.ebay.co....m-/371689357738
or cut out some your self.
yes you can run coil over shocks without the spring but seems an expensive option when there is nothing wrong with your current ones that could not be fixed for a few pence.
#12 Spider
  • 14,638 posts
Posted 31 March 2018 - 08:34 PM
They look an ACE idea Nick as long as they are rubber and not poly.
I've seen similar types, but not ones that are so simply adjustable like these.
#13 nicklouse
  • 18,377 posts
Posted 31 March 2018 - 08:46 PM
the ones i were looking for were hard shims that you just added above the rubber on the shaft to move it down.
#14 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 01 April 2018 - 02:58 PM
Just taken one of my rear Spax shocks off. No bump stops fitted and no way to disassemble and fit. Who makes an adjustable shock with fitted bump stops?
#15 Midas Mk1
Midas Mk1
  • 5,754 posts
  • Local Club: S.U.N.M.C
Posted 01 April 2018 - 04:57 PM
I tubbed the arches on my sportspack to stop them rubbing on large bumps, doesn't help that the sportspack arches sit so high up making the car look higher than it is. A lot more clearance now for suspension travel :)
