Charcoal Canister Removal
Posted 24 March 2018 - 10:31 PM
I've got the one from the crank case breather to the carb which just leaves the metal pipe running back to the fuel tank breather spare.
Any ideas folks? Ta
Posted 25 March 2018 - 08:54 AM
The earlier cars had the breather from the top of the tank straight out through the boot floor onto the road.
Posted 25 March 2018 - 09:32 AM
Posted 25 March 2018 - 04:01 PM
Posted 25 March 2018 - 06:07 PM
Just into the engine bay? And the other pipes right as I've done, breather into carb.
I disconnected the rubber hose at the engine bay end of the breather return, there is also the Y piece that needs blocked
Posted 25 March 2018 - 08:23 PM
Posted 25 March 2018 - 09:18 PM
Does the y not need connecting to the carb?
You need the one with both engine oil breather cans connected to the carb. The two for the charcoal canister can be closed( I slid a bolt into the ends of the hoses and clamped closed with a jubilee style clip)
Edited by cal844, 25 March 2018 - 09:18 PM.
Posted 26 March 2018 - 12:05 PM
