1997 Rover Mini 1275Cc Carb Engine
10 replies to this topic
#1 AndyPhill
AndyPhill
  • 45 posts
Posted 17 March 2018 - 06:33 PM
Hi,
I am thinking of selling my Mini which I have owned for 6 years and thought I should get it valued first.
The original Mpi engine was swapped by previous owner. It has a single carb 1275cc Engine with uprated distributor and Nology Spark plugs.
It has had a new front end except the bonnet,scuttle and inner wings. fitted 2013
Hi-Lo's
New Supalight Alloys fitted 2012
New Radiator fitted 2012
New Sills fitted 2013
New Stainless steel grill and headlamp surrounds fitted 2013
New halogen Headlamps fitted 2013
New windscreen and seal fitted 2013 (windscreen has a small chip in mid passenger side)
New Heavy duty Tie Bar rods fitted 2013
New Complete Exhaust and Manifold fitted 2015
It Needs:
Sump plughole thread repair or new outer casing. Currently has emergency plug on it which is doing a good job.
A new rear subframe
A patch over the box section of the sill on driver side wheel well
Some rust repairs in boot and outer body just below rear windscreen.
Rear windscreen seal
Gear selector seal repair. (small oil leak from it)
The air intake holes have been repaired and blocked off to prevent water getting in. This is reversable.
here are some pics
I was thinking around £1800 to £2000 as it does need work and the interior may not be to everyones taste. Is that too high?
Andy
#2 Boycie
Boycie
  • 1,978 posts
Posted 17 March 2018 - 08:02 PM
I think your valuation is about right and what it would achieve on ebay, with a bit of luck.
The fact it's lost the right engine is an issue, but not enough to put off a proper Mini person and the body looks well redeemable.
Good luck with the sale.
#3 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 17 March 2018 - 10:41 PM
I agree think you are not too far off.
That rear subby is well rotten! Lol
#4 AndyPhill
AndyPhill
  • 45 posts
Posted 18 March 2018 - 09:19 PM
O.k thanks guys. Yeah the subby is abit crispy lol
Still undecided on whether to sell it or not yet.
#5 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 19 March 2018 - 10:06 AM
Where are you located? Just out of curiousity
#6 whistler
whistler
  • 1,788 posts
Posted 19 March 2018 - 11:53 AM
I think one of the issues with a carb engine in a 1997 car is whether it would pass the emission test for an MOT.
#7 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 19 March 2018 - 01:34 PM
A valid point. Would need to be leaned to within an inch of its life for the test. Or require the probe inserting into an exhaust not connected to the engine lol
#8 Boycie
Boycie
  • 1,978 posts
Posted 19 March 2018 - 02:18 PM
I'm pretty sure the MoT emissions test goes on the age of the engine, not the car itself.  Maybe you'd have to provide proof of when your engine started life, however...
Also, I think the rules are about to change regarding emissions.
#9 Mervyn
Mervyn
  • 256 posts
Posted 19 March 2018 - 02:22 PM
MOT emissions are currently tested on age of engine OR car, whichever is oldest. Providing you have some evidence of the engines provenance then it will be tested at that age
#10 AndyPhill
AndyPhill
  • 45 posts
Posted 21 March 2018 - 02:22 PM
I am in Chirbury, Shropshire.
The garage I took it to had the same concerns regarding emissions but the only thing it's failed on was lack of a battery strap (hence the homemade one in one of the pics) I am pretty sure some tweaking was done to get it through the test and then reverted back. I do remember him saying that he might be able to do it without the CAT on it but this was nearly 2 years ago.
I was gutted when I found out the engine had been swapped and the floors were rotten (which have been sorted)  but it's my own fault for not doing my homework or bringing someone with me who knew cars.
Edited by AndyPhill, 21 March 2018 - 02:29 PM.
#11 AndyPhill
AndyPhill
  • 45 posts
Posted 21 March 2018 - 02:35 PM
I have an emissions test for catalyst equipped vehicle from 2013
Fast idle
CO  0.01%
HC  38 ppm
Lambda 1.02
Natural Idle test
engine speed 879 RPM
CO 0.01%
I had no provenance whatsoever so I am guessing that is why he did the CAT test.
Edited by AndyPhill, 21 March 2018 - 02:41 PM.
