Hi people.
I have in inherited a 1995 mini shell along with a 1974 ish engine. ( engine code - 99H791)
Now my issue is buying the correct wiring loom. do I buy one for the era of the engine or the car? as the car would of been a mpi?
or do I fit as much as I can and take it somehwhere for a custom one? as you can tell I have no idea what to do and this is the part of the build scaring me the most.
any help will be greatly appreciated
Posted 17 March 2018 - 01:44 PM
Posted 17 March 2018 - 02:31 PM
Posted 17 March 2018 - 03:30 PM
If you have the shell with no loom then use the engine year one, if its still wired then as Cal said above.
Posted 17 March 2018 - 04:01 PM
Are you sure it's an MPI? Could well be an SPI instead, what model does it state on the V5c?
Posted 18 March 2018 - 10:57 AM
Posted 18 March 2018 - 11:02 AM
Would it be an idea to fit everything and then contact autosparks as I don't know exactly what will be going in the car as yet
That could be an idea
Posted 18 March 2018 - 11:14 AM
Posted 18 March 2018 - 12:38 PM
I'll do that so I'm not committing to anything ad this will be my retirement fund (I'm 23)
If your 23 I wouldnt worry about retirement too much. Probably wont live long enough to see it. Retirement age will be 105 by the time we get there
Posted 18 March 2018 - 12:41 PM
It depends on what you got with the shell and what you want to end up with. A bare shell is like a blank canvas, it can end up any way you want it from a sixties minimalest single clock to a fire breathing turbo with big sound system and electric everything fitted. You need to set out a plan for what you want to fit and than talk to someone about how to go about it. The '95 loom is a great loom to start with if you want many extras
Posted 18 March 2018 - 06:14 PM
Autosparks were really good when I rebuilt my pick up
They can customise it, too. I had relays incorporated for the lights.
Top firm, but Wired by Wilson is Ab Fab, too.
Posted 18 March 2018 - 10:22 PM
Have used wired by Wilson for a previous car, top bloke and also a TMF trader 😉
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
