1275Gt Resto - From Flip To Factory
clubman
400 replies to this topic
#391 Verderad
Verderad
  • 413 posts
Posted 09 July 2024 - 01:41 PM
What a dissapointment after all the hard work and so near to completion, what speed were you doing?
Hard to tell Speedo decided to give up, I expect whilst it sounded loud, probably no more that 30.  I live in Wales where 20 is plenty.
Speedo was ok, then bounced around before stopping.
Just another task of classic car ownership
#392 Verderad
Verderad
  • 413 posts
Posted 26 January 2025 - 06:10 PM
Wow its been a long time since I’ve been here.
Visit to Mini show today and picking up a few bits has provided inspiration for an update
following the disappointment I of damage to scuttle and paint i decided a quick repair to allow for some use over what was left off summer.
I had another go at pushing out the dents, welded the tear, straightened out the drip channel.
Removed the flacking paint and prepped for a prime and paint.   The filling will happen when it goes to a professional, will need the windscreen surround and scuttle to be painted, hopefully being fresh paint it will bend into the joint between wing and scuttle.
Not perfect, not even close but it will prevent rust until its done
Wasn’t sure about the head being modified for unleaded so I purchased a head from Steve at SG Moto
had the right spec
12G940 head  unleaded inserts fitted, 35.6mm inlet 29.4mm exhaust,
160lb double valve springs.
stripped off the current head to find some worn shiny bores with a little more that light scoring.
Its also bored to +20
Block  has a couple of letters stamped into it
Any ideas?
Added a new set of rockers at the same time.
Took a lot of time to get them gapped correctly, would have though after the first 2 that it would be possible to remember which way to turn spanned and Allen key!!
Oil change at the same time, not happy with what was on the sump plug.
It runs, i can drive it
Edited by Verderad, 26 January 2025 - 06:45 PM.
#393 Verderad
Verderad
  • 413 posts
Posted 26 January 2025 - 06:59 PM
Who wants a car that just runs, needs to be the best it can be.  Booked a visit for AC Dodd
very happy with the outcome.
Fron 4:52
https://youtu.be/kQC...-aGejR_JoVjEA-T
Made use of my own sensor for tuning, went out several times to get it right.   Airbox now looks like Swiss Cheese so many holes drilled it.
Needed a new dizzy to replace the new dizzy fitted by a local garage.  That one didn’t have the right curve for my car.
#394 Verderad
Verderad
  • 413 posts
Posted 26 January 2025 - 07:07 PM
Turned out ok.
Finished off all the interior, new rear parcel shelf cover, trimmed out the dash and fitted the air vents
#395 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 26 January 2025 - 08:02 PM
Looking good mate, I could do with a visit from AC
#396 Verderad
Verderad
  • 413 posts
Posted 26 January 2025 - 08:06 PM
Thanks Jimmy, it’s well worth it.
#397 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 27 January 2025 - 05:33 PM
Cars looking good, and after AC's visit running great, all that's left for you to do is enjoy putting some miles on it.
#398 Jase
Jase
  • 1,167 posts
Posted 05 April 2025 - 05:01 PM
Turned out ok.
Is that South Cornelly?
#399 Verderad
Verderad
  • 413 posts
Posted 19 May 2025 - 02:02 PM
Turned out ok.
Yes, Braceys yard
#400 Kevybmini
Kevybmini
  • 120 posts
Posted 28 June 2025 - 09:16 PM
OMG
#401 lippo
lippo
  • 163 posts
Posted 29 June 2025 - 02:56 PM
Great thread, the car looks infinitely better than it did when you first started, I'm so glad those moulded arches have gone. Lovely colour, the interior looks amazing and I'm glad the visit to AC helped a lot.
 I've seen the heads from S G Moto on FB, would you recommend them? Feel free to message me if you prefer.
Also tagged with one or more of these keywords: clubman
    Bing (1)
