I’m back. I’ve driven it…….
Interior in, carpets, seats, window winder, removed when runner came off?
bent driver regulator, replaced
chipped paint with window glass.
Door cards and furniture in
Door handle on passenger side needed some / a lot of fettling
had to grind handle and the door.
Skin too far over the door frame?
Had to elongate the holes in door skin
Handle covers it
Happy with the progress, just need to sort out why hazard inline fuse keeps blowing.
Started with some research
not a lot on that circuit. Hazards and Interior lights
worked way through the circuit, checked hazard switch
Cleaned all ok. Checked voltage on all point of switch all good.
disconnected stalks
Jumped power at connector, voltage disappears on RH indicators?
Stripped out new flashed units, stripped out brake fluid switch, removed usb power. Put old flasher in. Nothing…. Cried….
Left garage for weeks…
No interior light fitted, hmmm
no cables, behind head lining…. Possibly earth on body
Fitted light, comes on, all appears good with hazards.
turn off light, fuse blows.
Left garage for weeks……
strip out door switches for interior light, swap cables around in interior light, this should make no difference.
Interir light works, put door switches back in, interior light turns on an off.
Add new flasher units with earth back in,
Yes all working
Wire brake fluid switch back in, re taped loom.
All still working.
Changed the voltage stabiliser on clocks, fixed wobbly bulb.
All working, happy days.
Went out for a spin. All working, push hazard switch into mounting, No indicators. Assuming wire disconnected.
Put front bumper on
Now just need to work out why it runs so rubbish. Seems to be rich, bit smoky but it runs, stops
