1275Gt Resto - From Flip To Factory
clubman
396 replies to this topic
#346 Verderad
Verderad
  • 411 posts
Posted 13 May 2023 - 02:48 PM
Refitting the Clutch housing, would appear to be an easy job???
I thought that it had slipped on easily, slight gap at the bottom that I tried to pull with the bolts.
Loud bang
Cracked the housing, one of the bearing pins had come out, broke in half and was on the end of the shaft.
Gutted, spent £40 having it vapour blasted.
Couple of posts on Facebook looking for a replacement.
Big Thank you to Ross Thomas of Thomas Classic and Modern for not only providing replacement but also fitting new bearings and then meeting in local services to deliver.
More cleaning of parts
Fitted new clutch, removed new clutch, rotated to align with markings - Read manual before not after.
Then I found this on the bench
first time was just for practice.
Progress
I had fitted the Radiator but had to remove to get a socket on crank to turn engine for refitting distributor and adjusting the rocker gaps.
Not sure if it needed any shims to make up the difference in flank thickness or if the gasket will deal with that
Then onto the carb.  Just a clean on the outside
Then decided on a quick look inside
Full strip down and rebuild.  I can see many hours of adjustment to get it running correctly but that’s all part of the fun.  Then Call out AC Dodd.    Lost a morning to YouTube videos of tuning minis.  Very interesting.
Realised that cleaning the needle with a green scotch brite to remove the crud has now probably ruined the needle.
Will fit the one that came with stage 1 kit and hope it runs
Edited by Verderad, 13 May 2023 - 02:56 PM.
#347 Verderad
Verderad
  • 411 posts
Posted 13 May 2023 - 02:53 PM
Found these in a growing box of parts that I’ve bought and not fitted or maybe forgot I bought and ordered another.
Which resulted in this
Rebuilt both sides.  Its so much easier on a bench!!
Then fitted handbrake cables.
Wow thats not a 5 minute job.
Probably had 3 or 4 goes then Read manual.
When your arms are not long enough to hold ratchet and screw driver
More little bits fitted that you wont see
#348 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 14 May 2023 - 07:12 AM
Seeing your progress with washers, did you install the handbrake sealjng pad?
http://www.minispare...22.aspx|Back to
#349 Verderad
Verderad
  • 411 posts
Posted 14 May 2023 - 07:32 AM
I had some foam that I cut to shape. I also fitted the old plate on the underside but the other way around
plates held in with bolts and lock nuts.
Edited by Verderad, 14 May 2023 - 07:34 AM.
#350 GT Jimmy
GT Jimmy
  • 1,639 posts
  • Local Club: S.U.N.M.C
Posted 15 May 2023 - 08:27 PM
Looking good, won't be long now
#351 Richard e
Richard e
  • 103 posts
Posted 16 May 2023 - 09:37 AM
I’d check the routing of brake pipes to the dwp valve: top m/c to left - or mines wrong- my brakes work fine - risk of locking up rear if reversed?
#352 Verderad
Verderad
  • 411 posts
Posted 29 May 2023 - 07:04 AM
Thanks Richard. Will have to look in the manual.  It’s the same way round as it was when I stripped it. Checked the photos. However there have been one or two things that were not right.
#353 Verderad
Verderad
  • 411 posts
Posted 29 May 2023 - 07:54 AM
I realised I’ve been putting this part off…..
Daughter there to turn the handle
10 minutes of sticking subframe bolts to screwdrivers and hole alignment, engine in.
  Very pleased.
Went so well when I realised I had not connected the heater take off to the bottom hose!!  I nearly took it back out
Getting bolt past the exhaust down pipe was a challenge
What I haven’t got pictures of is the 50 times I got under the car, looked at bottom hose, got back out!!
routed in the electrics, wired in all except the front lights, new light lense to main harness needs to be made up.  That part is missing or attached to the flip front.
Edited by Verderad, 22 June 2023 - 08:42 PM.
#354 colinf1
colinf1
  • 1,009 posts
Posted 29 May 2023 - 10:12 AM
You done very well to get the engine in with the downpipe and carb attached!
On my clubman I lifted body over the engine/subframe combo, but on my current I lifted it in with hoist.
#355 Verderad
Verderad
  • 411 posts
Posted 22 June 2023 - 09:20 PM
Spent an hour getting car off the axel stands and beams back on to Axel stands to get exhaust pipe on.
Had to remove the gear change to Turn the bolt that hols the bolt around to clear exhaust.
What is this bracket for?   It was on the down pipe
Then on to speedo. Strip and clean
All back together, new bulbs etc
thank you @chris1275GT for the clips to hold the glass in place
Waiting on this to finish the assembly
Onto the rest of the headlight wiring
Solder on the new bullets
Used the blow torch method
Create loom assembly
Then fit headlamp bowls, but first spend 3 hours looking for the packet of screws
side tracked into sorting draws of screws, bolts, machined screws etc
still can’t find screws
Starting to look like a clubman
Cant fit the offside side light,  really should have tried this when it wasn’t painted
Drastic action, unfold
but first heat with wife’s hairdryer
Then fold back with mole grips and cardboard
It worked!!  No cracking of paint
Needs a little bit of dressing when I have a 2nd pair of hands
Headlamp wired
Not sure why it has the side light on the main build
Got carried away with the side lights, cleaned off all the under seal  then cut off the wire and re-wired.
lost another half a day, that’s minis and the garage of lost time…..
Lense looks a bit shabby, I’ve ordered new ones (they don’t look much better!!)
Put the wheels on whilst i moved the axel stands, added the hub caps to see what it will look like
Not sure about the old English white steels, looks like there are white walls on the tyres.   I think silver to match the stripes on the hub caps
Thought the next job would be drive shafts, nice easy job!!!!
I’m still cleaning grease from places I can hardly reach
#356 MrBounce
MrBounce
  • 2,635 posts
Posted 23 June 2023 - 03:05 PM
That bracket is used as an exhaust steady bracket and attaches to the gearbox  :thumbsup:
#357 colinf1
colinf1
  • 1,009 posts
Posted 23 June 2023 - 04:30 PM
There is another bracket that attaches to the diff output cover, it's here
https://www.minispar...gs/GEX7526.aspx
Edited by colinf1, 23 June 2023 - 04:31 PM.
#358 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 23 June 2023 - 08:49 PM
Great work, it's coming together very nicely!
Don't forget the split pins in the handbrake pins.
#359 TheBrownClubbyEstate
  • 11 posts
Posted 27 June 2023 - 07:37 AM
Just spend a good few hours admiring this thread! Love the time and dedication folks on this forum put into working on these awesome little cars, and to then take the time to photograph, write up and share with us all! Hats. Off.
#360 Verderad
Verderad
  • 411 posts
Posted 28 June 2023 - 09:58 PM
Well this weekend didn't go as I wanted..
Only had to fit one drive shaft, bit of wiring and start the car......
Started with the clean jobs
Fog light Switch
Had to work out the wiring on bench before getting in the car.
Needed a new earth lead, wired into the same one as the heater.
Fit rear fog lamp
but first deal with the couple of rust spots on back of bumper, treat and a bit of clear lacquer.
fitted rear bumper, attached fog lamp. Drill hole in fresh paint of valance, fitted grommet
Fog lamp is an early 80's NOS cheapo £4 period item..
Switches fitted, will get new ones on order as they all look a little shabby.
Lots more messing about with cleaning battery terminals, fitting grommets etc
Then it was attach battery time......
Heater fan came on as battery terminals attached, thats one of the list.
Lights on, side lights ok, main bean took a while to come on??
Hazards - all working, flash a little slow
Indicators, left on, dash light on, not flashing. Right on, no dash light, not flashing.
Read forum, already read through many on Slow indicators.
Worked through the earths, added earth from indicator / side lights into loom, too much new paint for them to earth through body.
No joy.
Swapped hazard flasher and indicator flasher, better. Changed the connectors on indicator flasher.
Put bulb back into dash indicator light!!
Still not flashing
Changed bulb that didn't have any markings on.  Flashing !!!
Whilst lookin at the forum there was a suggestion that changing the bimetalic flasher for modern is a better solution. I have one of those from an incorrect purchase.    Needed another earth lead but the flash is now very consistent and brighter.   Ordered another unit to replace the hazard flasher.
Lights all good, main beam really slow to come on?
Checked all earths, some not a tight in new connectors, quick squeeze with the pliers.
Then I noticed the main earth onto bulkhead was not tight, bolt not doing up tight, thread in bolt knackered.
Tapped out to 8mm.  Amazing difference.
Brake lights staying on.
Not enough adjustment to move the switch back far enough.
screw added, now works fine.
Onto the heater plumbing.   Why is it that the outlet on the heater matrix is in the wrong side?
Having fitted the heater, decided the best option was to remove and rotate the matrix.
New holes
Plumbed in
Also tagged with one or more of these keywords: clubman
