You can buy stainless steel versions of these:
Posted 08 September 2022 - 09:46 PM
Posted 08 September 2022 - 11:50 PM
It’s dense with underlay. Will get the name tomorrow. How much do you need?
Posted 26 November 2022 - 12:10 PM
Wow its been a long time. I have been in the garage a couple of times to fit front subframe.
Where are the bolts? Mess around looking from them, buy new ones……
Paint tear drops again, thing time trip back to bare metal
Forgot about the front sub, started on cleaning up door catches
pondered about drilling out the rivet, decided putting in a new one would be more of a ball ache than masking up
Finished off fitting front sub, made spacers for sub to front panel
Thats about it
Now need to decided on fitting out doors and windows or wait until after paint issues rectified
Posted 02 January 2023 - 03:48 PM
Before the wheels go on want to finish brake system
bought a clutch and brake master on eBay about 2 years ago.
Will clean up the newer and originals go with the best.
clutch
might clean up
Its a bit thin, went through when cleaning
This will clean up
stripped down both, wish I had ordered the service kit first, I would have left the temp sensor in place!
Through the clean, etch, scotch brite, degrease, prime paint cycle
will finish off when the spares get here
Almost ready to start this
It’s been sat quietly in the corner of the garage for 4 years. Other than unleaded conversion not sure of any other work
Started with this
Strip and clean
Bit of etch, metal was cold so popped it in the oven for a bit
paint kept in house, into pan of hot water when in garage.
Posted 02 January 2023 - 05:24 PM
Good progress, the gear stick housing is one of my jobs to do next. How long before you get the car back on the road?
Posted 05 March 2023 - 09:31 PM
Been away from garage for a bit, some aspects of the car not making me happy.
Having built the brake master, I had a nagging doubt that the top piston and spring may have separated when I assembled.
how to get it apart?
Spent time finding old fitting to block holes, then applied pressure with a foot pump. Shot out, used some brake fluid to put it back together
Onto to the clutch master
Oh no, where is the bag with the new rubbers??? Grrr. Tear garage apart, swear. Move onto next item ….
put the gear change back together
Pleased with that, will get some heat shrink for the reverse switech.
Installation time
Not sure what to do with brake switch thing, they don’t make them any more.
I have the top and parts from the original, might see if I can turn one down. The bolt kind of fits, not sure what the thread is.
Next week will be start of engine strip, might just end up being a clean and install.
Time to get driving
Posted 06 March 2023 - 08:37 AM
Isn't it lovely when you put shiny parts in a nice painted shell? Looking good!
Posted 12 March 2023 - 05:00 PM
Posted 13 March 2023 - 01:13 PM
Just read through your whole thread here. I remember when you started this and it was just a few pages long. Won’t be too much longer now!
Posted 26 March 2023 - 09:44 PM
Started This. Not going to do anything other than clean it, replace a few seals and gaskets.
Striped off all the ancillaries, all need a good clean or replacement
Big Minispares order in for bits and pieces, gaskets, seals, water pump, hoses etc.
Clutch housing and wok has gone for soda blasting along with radiator cowl, brackets, pulley, anything else that needs cleaning.
Degreased and covered with paint stripper, looks like the engine was originally gold. Replacement engine? Is it the right spec for a GT? It’s a 1275 but how do you tell if its correct for a 76 GT?
Hoped that jet wash would remove all the paint. Oh the disappointment.
Out with the wire wheel. Most used item on this project
Then up onto the bench, can’t be sat on the floor.
Then attacked with small wire brush in the drill before sand paper and lots more degreaser
Gave the bottom a good clean whilst in my head “no one will see it”
more degreasing with panel wipe and lots of rags.
Etch primer on
Satisfying afternoon and evenings work
Edited by Verderad, 26 March 2023 - 09:48 PM.
Posted 27 March 2023 - 12:37 PM
Lovely!
Posted 28 March 2023 - 09:02 PM
Parts back from the blasters.
not sure how to finish the wok to stop it going dull. Clear furniture wax or clear lacquer?
rubbed over the etch primer on the block with green pad. Then lots of panel wipe for all the parts to be painted.
on with the etch
More primer on the parts tonight
block into black satin.
thought I would get the bottom pulley off.
used little chain wrench to hold it, nice fit I’m pulley groove.
oh no, broken it…. £120.
will wait until starter ring is back on to undo that nut.
Posted 28 March 2023 - 09:11 PM
Posted 13 May 2023 - 01:50 PM
Posted 13 May 2023 - 02:30 PM
Finish rebuild of Clutch Cylinder
Little bit of wear
Spare retrieved from the might need this box…
Service kit fitted then installed
Probably the best part of an afternoon lost on that little job.
Stripped of the lower pulley, 2 man job to hold crank still, engine steady on bench. Once the nut was undone the pulley came off with ease. I did think the pulley movement was excessive end float it moved so easily.
My friend Tim went home to find me a lower pulley, returned with a box of them…. Mini ownership is really about collecting parts you might need.
Looks tidy
Then strip, clean, paint
I then decided that it would be best to run some cleaner through the block, it was pretty grim in there.
Put the old water pump back on, fitted hoses, filled the system through heater valve then ran water pump with a drill with a bucket replacing the pipes. Didn’t get the flow I was expecting?
Then just filled and emptied the system a couple of times.
finally ran out clean. Another 3 or 4 hours of time lost in the garage .
Projects →
Mini Saloons →
Black 1979 1275GtStarted by StuaR32t , 15 Feb 2025 ![]() |
Projects →
Mini Saloons →
Cape Town 🇿🇦 1275HleStarted by JAYO , 28 Feb 2021 ![]() |
Projects →
Mini Saloons →
Budget Mini Clubman Shell Restoration For £1500Started by minimissions , 13 Nov 2019 ![]() |
Projects →
Mini Saloons →
1275Gt Tarmac Rally Car - From ScratchStarted by KRM_Simon , 26 May 2019 ![]() |
Projects →
Mini Saloons →
1977 Leyland Mini - 1275Started by parrellan , 27 Oct 2017 ![]() |
