1275Gt Resto - From Flip To Factory
clubman
396 replies to this topic
#211 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 23 February 2022 - 03:11 PM
Looks fantastic Ben, what stopper is that?
It's my paint suppliers own brand but it's generic stuff and can be got with multiple different brands printed on the stickers. It's all the same thing though
#212 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 24 February 2022 - 03:06 PM
Got the step, door and a panel levelled off
Thats this side complete
Ben
#213 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 24 February 2022 - 04:50 PM
Onto the other side now.
There is an issue here however.
The doorskin has a bulge in it
No amount of hammering will move it. This is due to the adhesive between the skin and the frame has been super heated when welding to the edge of the skin and then it's set again causing the bulge.
And so it was decided to take the solution of replacing the door skin again.
It's now all cleaned up ready for the new skin
The owner also reported that he wasn't happy with the finish of the A panel this side so I'll replace that too
Ben
#214 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 25 February 2022 - 04:46 PM
I've had lots of stuff to do today so only managed a couple of small jobs on the GT.
A panel removed and cleaned up readybfor the replacement
And I also welded in the lower rear seatbelt mounts.
Ben
Edited by Ben_O, 25 February 2022 - 04:47 PM.
#215 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 28 February 2022 - 03:16 PM
I have a door skin now so time to crack on.
So I laid the frame in and folded the skin
The first try on the car didn't go very well
It seems the problem is caused bu the A post being twisted which would explain the need for the welding rod on the previous A panel so I straightened the A post and tried again
That's done the trick.
A panel next
After a bit of tweaking, it's getting better
And then I welded on the A panel
Just the skin to weld to the frame now and then I'll have a look at closing the gaps up a little.
Ben
#216 Verderad
Verderad
  • 411 posts
Posted 28 February 2022 - 05:49 PM
Ben what did you have to do to straighten the A Post?   I've seemed to have all my problems with this side of the car.
The gaps look good already.   I expect now that the A Panel has been removed that the wing has moved in, which in turn has allowed bottom of A Panel to move over at the bottom.   This is where I had front of car propped up to get the levels correct but the packer on axel stand on that side had fallen off.
Looks great already.
#217 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 28 February 2022 - 06:36 PM
The flitch/A post section was too far forward. The bottom more than the top so I had to dress the post over to kick the door up at the back and also take the whole thing back.
Everything seems to be exactly where it needs to be now and since the update above, I have reduced the spacing on the door hinges to bring the door forwards closing up that gap to match the other side and I'll add welding rod to the back edge of the door to match the width of that gap to the other side too.
Ben
#218 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 01 March 2022 - 01:02 PM
I've finalised the door gaps now by reducing the shims to bring the door forward and adding welding rod to the back edge
Ben
#219 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 03 March 2022 - 04:51 PM
Been at the filler work again
Then after a much needed clean down, I can start on the next bit.
The roof
First job was the clean back to bare steel
The skin has lots of stretching, dents and low areas so I started by straightening the worst of it.
I can only go so far without stretching the steel too far and worsening the work hardening so the only option to finish it off and get it flat is the filler
Ben
#220 Verderad
Verderad
  • 411 posts
Posted 03 March 2022 - 05:20 PM
I knew when I started to strip off the paint and found lots of filler I should have stopped stripping. Oh well it’s in good hands.
Looks great already. Will be too excited for a grown man when the primer goes on
#221 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 17 March 2022 - 04:07 PM
I've finally got the roof work done.
It ended up being a lot of work but I'm happy to put it into primer now.
Before I prime the shell, I want to get it onto the rotisserie so I can prime the whole shell in one go but the frames of the rotisserie obstruct the body in some places so I have epoxy primed the engine bay and inside the boot accordingly.
As soon as that is hardened I'll mount it onto the rotisserie and get cracking with priming the rest of it.
Ben
#222 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 18 March 2022 - 07:32 PM
The shell is now mounted to the rotisserie  and the underside has been stripped back to bare metal realy for epoxy on Monday.
Ben
#223 Verderad
Verderad
  • 411 posts
Posted 18 March 2022 - 10:04 PM
What did you use to wipe the zinc primer off with?
#224 Verderad
Verderad
  • 411 posts
Posted 19 March 2022 - 11:02 AM
Ben do you seam seal after primer?
Looks good in the first primer, did you use an isolator? I had sprayed the inside of rear quarters with a rattle can top coat.
Looking good
#225 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 19 March 2022 - 12:01 PM
I ended up sanding off the primer with p120
Looking good
I used an isolator in the boot over the paint on the quarters and the rear bulkhead just incase.
I also put a fine coat of isolator on the remains of the white primer on the front end panels just incase.
I shall be epoxy priming the underside of the shell and then once cured, will key up with a scotchbrite and seal up right before the tinted stonechip goes on.
A highbuild primer will be used on the outside of the shell so that all the final leveling out can be achieved when that it flatted prior to topcoat.
Ben
Also tagged with one or more of these keywords: clubman
