1275Gt Resto - From Flip To Factory
clubman
400 replies to this topic
#181 Verderad
Verderad
  • 413 posts
Posted 05 September 2021 - 08:54 PM
Battery earth cable I suggest but sorry I'm not expert enough to detail the exact position
Thanks Mark, Thats jogged my memory.
#182 Verderad
Verderad
  • 413 posts
Posted 13 September 2021 - 10:14 PM
Well fitted the door rubbers and catches. Drivers door needs a little work to get it aligned at the rear and long the bottom of the door.
Passenger will need lots more work, the fit at the Bottom is terrible, and it stick out on the rear bottom a lot. Pics to follow for lots of that good advise.
I expect its going to need top hinge moving out a little, the A-Panel adjustment with suitable weight adjuster.
Then probably more hours moving catch in all directions until it looks reasonable
Going to buy the brackets for rear seat belts, just incase the wife and kids ever want a trip out. Can't add them once its painted, probably never get used.
Edited by Verderad, 14 September 2021 - 06:58 AM.
#183 Verderad
Verderad
  • 413 posts
Posted 03 October 2021 - 09:15 PM
Found some motivation to get back in the garage.   Didn't need a plan for the mini, so much body work to do, just turn up, cut, grind, weld, grind......
Last panel to strip the plastic, peel able paint from.  Boot lid, been hanging on the wall for nearly 4 years.
It looked ok, wrong rubber glued on rather that the one with wire hooks
Little bit of pitting behind the hinges, most of the dark spots are foam from the gasket behind the hinge.
Tin worm has eaten couple of large patches from the inner skin
Weld in a patch or just filler ??
Will give it a clean up to see what's needed
Krust Away
Good news is the outer skin is in excellent condition, one small dent to dress out and one that will need filler as its behind inner skin
Will get the filler out in the week.
Bargain buy at auto jumble  Â£20 what a steal
What a mess stripping a bit of paint a filler makes, glad I put full mask on today
Only 2 3 messy jobs left
Strip paint off roof, full of chips from stripping off the vinyl
Front sub frame
all the glue from the headlining
One bit of welding to close the hole in the rear bulkhead that my roll over jig went through
#184 GT Jimmy
GT Jimmy
  • 1,676 posts
  • Local Club: S.U.N.M.C
Posted 04 October 2021 - 06:20 PM
You're doing a great job mate, I chickened out of painting mine, good job my nephew owed me 30 years of Christmas and Birthday presents lol
#185 Jase
Jase
  • 1,169 posts
Posted 04 October 2021 - 09:36 PM
Looking good. Has to be the only active 1275GT resto at the moment.
#186 Verderad
Verderad
  • 413 posts
Posted 11 December 2021 - 01:15 PM
So much has happened, not as much as you think will get done, its a mini Resto.
Filler time, not quite the first bit of filler on the project, remembered why I'm paying to have the filler and paint done.  Its such a fine art that requires patience!!
This area won't show once the rubber is back on so i'm not going mad with the finish of filler, its flat and level, im sure the coat of 2K primer will be enough to flatten that out.
More bits to clean, I just over my wire wheel
The seam covers were full of filler / tiger seal, spent a bit of time with a grinding disk clearing out each one, absolute mess
sand and prime ready for fitting and paint.
Time for something different, not welding!!!!
This is dirty, old pic just before strip down to send Radius arms for refurb.
Strip down the brakes
Get all the bits ready for blasters 07521377674 Swan Aqua Blast, Based in Porthcawl Bridgend.   Great job, done in a day.
Into Paint, makes a mess but ends up with a nice clean part, this is something new after 4 years of filthy grind, weld, grind.
Then onto checking out the front sub,  its pretty good, couple of drilled holes to fill and one patch to let in.
Bought a new rear sub couple of years ago, started to give it a light sand so I could prime and topcoat, but lurking under the paint was lots of surface rust, started to strip it, then decided as the front was going for blasting and powder coat the rear can to.
oohhh shine and clean parts.
Now if you have read this far through build thread, its probably too late to say, don't leave your seats in the garage unless really covered well.
I don't remember mine having so many hot rock burns, maybe they did.
So operation clean the seats
The base on all of the seats are going to need replacing, one might tidy up but needs a rip repairing.  The other two are far to gone, lots of tiny burn holes
Looking for another back seat as a donor for new front seat bases. Anyone got one?
The rear whilst very dirty is in pretty good order.
Then onto the cleaning, used the carpet cleaner along with lots of vanish, which does a really good job
Lots of dust where it wasn't covered properly in garage, most hoovered off
Vanish it all
Now a quick strip down of the seats
Strip, sand, clean, prime then into paint
Next job, rear sub build, but first strip new radius arms of the thin coat of paint, then etch, prime and paint.  It doesn't end..
#187 JXC Mini GT
JXC Mini GT
  • 891 posts
Posted 11 December 2021 - 04:08 PM
Speak to Jase on here I purchased a set of front covers from him, I am in the process of having them fitted.
Great progress, it’s all looking good
Edited by JXC Mini GT, 11 December 2021 - 04:10 PM.
#188 Verderad
Verderad
  • 413 posts
Posted 19 December 2021 - 06:45 PM
Sometimes luck is with you, some guy responds to my market place advert in Wanted Seats, with a link to a set of MGBGT seats.
Only 40 minutes away.
They are in mint condition, just on cigarette hole in the seat base that should invisible mend.
They are in really good condition, seems a waste to use the material to recover my seats.
They also look more comfortable, and I do like the way they hinge forward and a head rest, which is probably a good safety feature.   Might have a look to see what the conversation looks like.
If not I now have enough material to recover 3 front seats.
Might get some garage action over the next couple of weeks, just might have all the parts ready to refit when Lady P comes back from paint in March.
#189 Verderad
Verderad
  • 413 posts
Posted 09 January 2022 - 10:49 PM
Onto the nice easy Jobs...........
Just remove the bolt out of the top arm!!!!!
little spray of penetrating oil each night for a week
Bit of heat with blow torch
More Spray
Big hammer, Bigger Hammer
Drill it out and ream!!!
One more to go.
New Threads into the Boot hinges
Boot lid is back on the car, first time in 4 years.   Just on as its comic back off for paint in 4 weeks !!! Yess
DhDyjtf.jpg?2
Had the passenger door back off, has rust spots come through where its been welded and the tiger seal burnt off.
Stripped back to bare metal, rust treatment, strip back and bit of zinc primer, will keep an eye on it before paint or it could be another skin. hope not but paint job cost significantly more than a skin and time.
#190 johnR
johnR
  • 2,325 posts
Posted 10 January 2022 - 04:55 PM
Good progress - building sub-assemblies like the subbies up is very satisfying
#191 Verderad
Verderad
  • 413 posts
Posted 30 January 2022 - 08:11 PM
Just 2 more brackets
Engine Steady onto Bulkhead
Might add a seam weld across the top
Battery Strap bracket
painted the inside, OTT?
Pulled up into position
Welded in and tidied up
That's it end of welding,   oh no wait, hole in back of seat !!
should be easy to fill in!!!  need arms like Mr Tickle to hold it from back and mark from the front.  messed about for ages then called in reinforcements Tim.
He held it I marked it, he then held it, pushed it, while I tacked it.
Bit of filler won't be able to tell it was there!!
Then that annoying niggle in your mind as you look at one of the first jobs repairing Bottom of rear bulkhead / seat back.   Its thin metal, looked terrible, had a hole.
Had to cut it out
I decided to have it over lapping at the back and plug weld into place.  Metal just too thin, even on low I was chasing it.
 Will add pic.
Finished......
I don't like the repair to gutter
I have a bit of gutter from the rood chop, not a corner though, so tried to bend it around a brake shoe
Bird poo
needs a little work
Done, I think
Now the last really dirty job, strip the roof
h15SamM.jpg?1
that feeling when you start a job, then think maybe I should have filled and sanded
More filler in there than I thought, 2 depressions that will need filler.   One pops out but easily pops back in.
My Garage now looks like the desert blew in.   That neat pile of dust sheets could have been used!!
Lots of sweeping, hoovering, wiping later garage can be used.
#192 Verderad
Verderad
  • 413 posts
Posted 06 February 2022 - 09:52 PM
Its never really the last messy job..........
Decided that I would go with the seat belt brackets, just incase I ever need to put my teenage kids in the back.
One turned up bare metal
Degrease, scotchbrite, degrease, etch, prime
Top coat the back, will never be seen again
Can't fit the seatbelt C Post Brackets with the original window closer bracket in place
Remove then, came off a treat with the new spot weld bit, been saving it for a special occasion.
gone
Can I just prime the bare patch after treating the rust?   What about all of the adhesive overspray from the headlining??
I tried to remove with panel wipe, not really, then panel wipe and green pad, then a scraper.  just messing about wasting time.    Time to wake up the neighbours, out with grinder and wire wheel.
all of the cantrail is covered in adhesive, on a roll with the wire wheel, did the whole lot, front and rear screen.  Quite satisfying seeing all the clean metal appear.
Then back to the original job, more prep, scotchbrite, degrease, etch, prime, top coat just behind the brackets, ground hog day......
Prep for welding, not going with weld through, just back to bare metal where the spot welds will be
Plug weld onto parcel shelf, not got long arms for the spot welder
No pictures of brackets fitted, will get one.
Messed around fettling the other seatbelt brackets, the joggle in them is not enough to get over the brackets already in place. Will leave welding those in to Ben, my welding not good enough in cramped places.
Fitted the centre seat belt bracket. Plug and seam
then stripped the temp primer and the rust spots from the rear seat.
Then stripped the companion bins
Spent an hour cleaning the bonnet catch pin, spring & cup.   then painted.  This is where the time goes.
Luckily I then spotted the number plate light fitting.   quick clean up of the oxidation bubbles under the paint.
It getting close........
#193 Verderad
Verderad
  • 413 posts
Posted 06 February 2022 - 10:01 PM
I then spent an hour picking underseal from the round metal pugs that go in the floor and seat base.
Now soaking in brick acid to get them nice and clean.
The things we do
I then read through Little Green @Mill Road.   Excited
#194 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 February 2022 - 01:18 PM
Nice work.
I'm looking forward to seeing it next week.
Ben
#195 JXC Mini GT
JXC Mini GT
  • 891 posts
Posted 07 February 2022 - 01:56 PM
Great work to get it to the stage where it is nearly ready for the paint doctor to work his magic.
How long is the car with you Ben?
I might get the chance to see it when I visit at the end of the month.
Regards
John
Also tagged with one or more of these keywords: clubman
    Bing (1)
