Camshaft Pulley Shim?
Best Answer Steve220 , 11 March 2018 - 04:49 PM
Well there we go
Rover gasket
DSN gasket
Both pulleys drifted home and flat edge shows...
Bang on!
Go to the full post
Posted 10 March 2018 - 05:21 PM
Posted 10 March 2018 - 05:34 PM
any shims under the crank pulley? is it seated fully?
Posted 10 March 2018 - 05:49 PM
As above are you sure there isn't any shims under the crank pulley? I cleaned mine, got it ground and balanced and didn't notice them until my crank pulley was sticking out a little. What make of chain/gears is it?
Posted 10 March 2018 - 05:51 PM
Also has the timing cover backplate been replaced by an aftermarket (alloy) version? Some of these are thinner than the factory original backplate.
Thinner backplate has the effect of moving the cam drive pulley towards the flywheel end, while the crank pulley is not affected by backplate thickness.
Posted 10 March 2018 - 06:12 PM
Just check too that the Cam is up against the thrust plate.
Posted 10 March 2018 - 06:44 PM
Posted 10 March 2018 - 06:48 PM
so what moved? crank pulley not seated?
Posted 10 March 2018 - 07:01 PM
Steve,
Worth checking the camshaft end float
Posted 10 March 2018 - 07:13 PM
Posted 10 March 2018 - 07:22 PM
Yes, camshaft end float is essentially the clearance between the triangular plate and the faces of the cam and cam pulley.
Clearance (ie camshaft end float) should be between 3 and 7 thou
Posted 10 March 2018 - 07:52 PM
Posted 10 March 2018 - 07:53 PM
Check the end float on the crank too, looks like the cam is ok.
Something has moved significantly...turning over by hand will not fix pulleys out by so much.
You say the crank pulley has always been torqued up...its not even fitted..?
Posted 10 March 2018 - 08:05 PM
Just measured the distance between the chain (once pushed home on the sprocket and tappet gently with a rubber hammer) and the backplate. The difference is 0.2mm/0.0078, the crank was the proudest measurement.
Edited by Steve220, 10 March 2018 - 08:06 PM.
Posted 10 March 2018 - 08:57 PM
Not sure how that works accurately, can't understand "the crank was the proudest measurement"..??
What did you measure the gap with?
End float should ideally be measured on the crank with a dial gauge, 0.002 to 0.004" is the aim
So if it is 0.078" its way off
