Hi all,
Having a clear out. All prices are plus delivery. You're welcome to collect from the Telford, Shropshire area!
MPi engine bay wiring loom - £30
MPi inlet manifold and throttle body with idle controller, MAP sensor and air filter housing plate - £35
Minispares inlet manifold, ported to 50mm inlet by Specialist Components - £20
Fuel rail and injectors - £10
Airbox with K&N filter element - £20
Fuel vapour trap £5
Coil pack bracket with coolant hose mount £postage
Clutch slave cylinder bracket £postage
MPi dipstick £postage
KAD water pump pulley painted silver on the outside but originally blue - £30
