Is there a way to test if this is ok prior to putting it back on car? Was working fine when it was removed but its been stood for few years. Indoors in a warm dry environment.
Edited by Steve8274, 08 March 2018 - 05:40 PM.
Posted 08 March 2018 - 02:34 PM
Posted 08 March 2018 - 10:33 PM
My test for them is see how far I can throw them and get them in the scrap skip.
Sorry, hate them and never put them back on, they make the brakes a pain to bleed up, and there is no test (that I know of ) to say they are working or not either on the bench or car.
So you can risk fitting an unknown quantity that has been dry for how long and not knowing if it works as intended or not.
They were a pointless idea in the first place and achieve nothing but unnecessary complication...
Like EGR valves cats automatic headlights, automatic wipers and electric handbrakes, 10 out of 10 for novelty value.
Apologies for the rant but I tend to from the Issigonis simple school of no radio, the ICE is under the bonnet.
Posted 08 March 2018 - 11:05 PM
Posted 09 March 2018 - 12:19 AM
Fam7821 uses the front circuit pressure to close off the rear circuit at a particular pressure differential. So, if you lose the front circuit, there'll be no limiting of rear brake effort and a failed rear circuit will be sealed off, reducing fluid loss and improving the effectiveness of what brakes you have left. Junking one could lead to some awkward explaining if the worst has happened and you needed to use your insurance.
Posted 09 March 2018 - 02:02 AM
Are you sure ?
If you loose the front brakes you are knackered anyway, it happened to me at 15, no valve to close of the rear circuit will save anything. The chances of losing your brakes these days are virtually Zero.
They are a theoretical impractical nighmare that can't be tested (to my knowledge).
Sorry Ethel your explanation is confusing.
Using an unknown probably un-testable braking item that is not needed is safe?
Posted 09 March 2018 - 02:58 AM
I'm with the Retroman all the way on this and them some.
They are an ingenious piece of crap to say the least.
What do you use instead then? Surely it must serve some purpose?
My car has the new type master cylinder so wont it put too much braking power to the rear if not fitted?
Sorry for all the questions.
Two options using factory bits.
1. Fit the old type shut off valve that was originally fitted to the front rail of the rear subframe.
2. Fit the one that came after that, the Inertia type Valve.
There are also some after-,market option too.
Posted 09 March 2018 - 10:53 AM
I really want to get hold of an old one and slowly pull it apart. Intrigued as to their mechanical operation and why the fail so regularly!
Edited by Steve220, 09 March 2018 - 10:54 AM.
Posted 09 March 2018 - 11:39 AM
Posted 09 March 2018 - 11:40 AM
Please don't apologise for the questions....it is a safety critical component.
The simple way to replace it is to use 2 M10 straight female joints on the bulkhead where the 'thing' sits.
This then creates a more normal simple Mini system with a front / rear split as per the twin line type master cylinder which you are using.
The T piece on your rear subframe then needs replacing with a conventional type Mini pressure regulator valve or an after market one.
Its a simple known solution, cheaper than a new pdwtf valve
PM me if you want the kit.
Posted 09 March 2018 - 12:09 PM
Many thanks for replying. I think I will go down this route. Are the pressure regulators like the ones I linked above? Are any better/more reliable than the others? I dont suppose you have a photo of one in situ?
Posted 09 March 2018 - 06:37 PM
Do you mean
http://www.minispare...74.aspx|Back to
Or
Or something else. How do these fit and do I need to redo brake pipes. I have just finished re doing them all.
Yeap., either of those. I do actually prefer the latter, but they are more fussy to fit as the fitted angle of them is important.
Posted 09 March 2018 - 07:49 PM
I agree it'll be a brown trouser moment with no front brakes regardless. I'm also a fan of the inertia valve, but insurers are mostly interested in protecting their profits, you could have a scrap on your hands justifying a modification from original equipment after the event. Remember that untestable item was original equipment that superseded your alternatives.Are you sure ?
Posted 09 March 2018 - 08:03 PM
Inertia valves were standard equipment on vans, I'm sure I've seen photos somewhere, but where?
Posted 09 March 2018 - 10:37 PM
I don't have any photos to hand, the only valve currently available is the adjustable type which can't be fitted in exactly the same position as the normal one. The adjuster comes out of the smaller end, which in a normal fitment goes in the hole on the rear subframe. So unless you can source a standard one the only option is adjustable. I can do them a few quid cheaper than MS too. their part No is MS72.
Posted 09 March 2018 - 11:36 PM
