Rebuild Sequence Help
Posted 26 February 2018 - 05:41 PM
Ive just got my car back from the paint shop and am eager to get on with the rebuild.
Problem is, Im not sure where to start or what order to do things.
Is there any recommended ways of rebuilding.
The car is currently on a dolly with no subframes on although I have rebuilt these ready to put on. I do know I will need to put brake and fuel lines on before these go on.
All advice appreciated
Posted 26 February 2018 - 06:18 PM
nothing internal untill it is on its wheels.
so pipes brake and fuel under the car. then subframes then finish pipework bleed and on it wheels,
Posted 26 February 2018 - 06:28 PM
As above. Don't forget to fit the steering rack before the front subframe.
Once on it's wheels, I like to fit the wiring loom, steering column and pedalbox as well as the master cylinders and then the headlining and glass.
Everything else after that can be fitted in any order however fit the rear lamps before the fuel tank.
Edited by Ben_O, 26 February 2018 - 07:00 PM.
Posted 26 February 2018 - 06:51 PM
Posted 26 February 2018 - 08:45 PM
Steering rack.
Brake and fuel lines
Wiring loom
Front sub-frame
Rear sub-frame
Suspension hook up
Wiper rack and motor
Engine & gearbox
Fuel tank
Exhaust system
Lights and electrical components
Internal trim
Doors
Windows/screens
External trim
Posted 26 February 2018 - 10:34 PM
Fit the rear shox and rear wiring loom before the fuel tank(s) as the shox top nuts and some electrical connexions are under them, I'd put doors at the end especially if you're in a single garage
Edited by johnR, 26 February 2018 - 10:35 PM.
Posted 26 February 2018 - 10:39 PM
Edited by johnR, 26 February 2018 - 10:40 PM.
Posted 27 February 2018 - 11:22 AM
Posted 27 February 2018 - 05:02 PM
I have body stands (easy to make and simple) that have the body at around 'bench height'. I do everything inside while on the stands, wiring, plumbing etc, then basically the last two major items to fit are the Subframes and the Engine. Fitting out the interior this way is much easier to get at everything.
Working from a bare (painted) shell, I usually build them in this sequence;-
Pedal Box
Master Cylinders
Wiring Loom
Demister Ducts
Dash (inc heater and switches)
Interior Trim
Doors (and Trim)
Hood Lining
Windows - at this point, the car interior is more or less 'sealed'.
Battery Cable
Under Body Pipe Work
Steering Rack
Rear Subframe
Front Subframe
Front Hubs
Brake Pipes (all)
Bleed Brakes - check for leaks
Fit Fuel Tank
Fit Engine
