1275Gt To Sa Gts Replica @ Mill Road Garage Iow
288 replies to this topic
#31 nicnoo
nicnoo
  • Just Joined
  • 212 posts
  • Local Club: south warwickshire minis
Posted 27 February 2018 - 12:56 PM
There's more rust on my cars AFTER I've restored them.
#32 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 February 2018 - 07:20 PM
A bit of information from the owner of this car regarding SA spec.
His Father was one of the team that set up the manufacture/production of engines and components at Leyland SA and he spent all of his high school and university holidays from mid 70’s – early 80’s working there.
The differences in spec were as follows
Engine bock (High level oil filter)
Compression (7.5:1)
Carbs (twin hs2)
Interior trim (local seat covering and carpets)
Arch flares
Stripes
The various changes/revisions that happened to UK cars over the years (70 – 80) followed within a few months in SA too.
Ben
#33 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 28 February 2018 - 06:19 AM
That's a fascinating connection with the Leyland SA factory and it makes so much sense as to why he wants to make a GTS replica.
#34 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 March 2018 - 07:48 PM
I had an hour this afternoon so a few more bits were removed
I removed these few bits
That's the battery + cable, the front shocks, the exhaust system and the selector box and rods.
And then dropped down the rear subframe
As you can probably imagine, it unbolted like it had been fitted yesterday.
The underbody protection that has been done at some point was done with the subframes in place so dropping it down revealed shiny Russet brown paint beneath the sections of floor where the subframe fits tightly to it.
I shall remove the front one next.
Ben
#35 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 March 2018 - 06:09 PM
On with the rest of the stripping today.
I need to get it booked in with the sand blaster asap so I better get a wiggle on.
I supported the front subframe with a pallet truck with some blocks and unbolted it before lowering it away from the bodywork
And then used another pallet truck to raise the body enough to slide the engine and subframe as one unit out from under the car
Then removed the last of the underbonnet parts like grommets, chassis plate etc
And then removed the pedal box and steering column as well as the fresh air ducting and fuel/brake lines
And now we have a bare shell
Still lots to do before it can go, namely removing all of the anti drum, dynamat and flashing tape that is plastered everywhere.
Rather than do that, I made a start stripping the subframes as they need to go to be blasted as well
Here is the front one after removing the suspension and running gear before lifting the engine out
And that's one down
Ben
#36 gadget555
gadget555
  • 152 posts
Posted 07 March 2018 - 01:16 AM
Stunning progress Ben!
#37 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 07 March 2018 - 05:12 AM
Nice progress getting the shell stripped. It looks to be in fantastic condition especially for a UK car.
#38 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 07 March 2018 - 06:38 AM
Nice progress I am still blown away by the condition of this shell..
#39 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2018 - 08:36 AM
Thanks guys.
It is remarkable really.
The worst rust I have found on the car is on the front bulkhead in the engine bay and this is only flaky paint and minor surface rust.
The true testament will be when it returns from blasting as there has been quite a lot of repainting of various panels done and there is no guarantee why and what may lurk beneath.
I did find holes drilled in the steps, B posts and door frames covered with plastic bungs. These were done to inject cavity protection at some point and this looks to have done a great job of preserving the shell.
Ben
#40 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 07 March 2018 - 09:52 AM
Good looking car! Ben the rust proofing thats been done to it looks like the same as I found
on my Contessa, what a pity the client doesn't want to keep it original! but HeyHo
each to their own as they say. Its good to see your keeping busy and sharing your work with
all on this forum.
Frank
#41 Jase
Jase
  • 1,166 posts
Posted 07 March 2018 - 02:13 PM
Excellent work, I'm finding I am becoming quite a fan of russet brown now :)
#42 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2018 - 06:25 PM
I think it's very Retro
#43 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2018 - 06:27 PM
all on this forum.
Frank
Thanks Frank.
The rust proofing is black and is in the box sections and on the inner wings and bulkhead. I have seen something similar on some 80's Fords and believe it was something offered by the dealerships.
Ben
#44 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 March 2018 - 06:41 PM
I started off the day by stripping the rear subframe
I now have a pile of suspension and running gear to sort through and refurbish
I removed the front shock mounts from the shell
As expected, it's clean behind.
I then started the thankless task of removing all the anti drum which takes a long time indeed.
Here is the boot part way through
And then finished
I then spent the rest of the day starting to remove the anti drum from inside the passenger compartment
The plan is to trailer it to the sand blaster tomorrow afternoon depending on progress.
Ben
#45 CityEPete
CityEPete
  • 3,920 posts
Posted 07 March 2018 - 09:45 PM
I was about to dynamat my floors but I'm guessing you wouldn't recommend it Ben? I've got brand new normal underlay to put in as I had a fuel leak that ruined my original rubber topped stuff and some of the factory bitumen deadening stuff.
