1275Gt To Sa Gts Replica @ Mill Road Garage Iow
288 replies to this topic
#211 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 June 2018 - 07:38 AM
Sorry for the lack of updates.
I was waiting for parts to arrive but since then, I have had lots of other work to contend with.
The owner of this Mini is in no rush for completion so it has been put aside for a short while.
In other news, the engine is now not being rebuilt and instead is going back in as it is. This is because the owner is not going to be able to use the car for a while due to work but has plans for an engine build int he future possibly with a supercharger.
Ill update soon!
Ben
#212 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 July 2018 - 12:38 PM
I have been doing a few bits and pieces the past few days and pretty soon, ill be pushing on with this to complete it.
I have added some brightwork to the front
And made a start fitting the headlining.
Once the new felt was glued to the inside of the roof, I inserted new rods to the headlining and hung it before going around the car with clips gently tensioning it before starting to glue the edges
It's a long and painstaking job especially in this heat but it's gradually getting there. Please excuse the dusty marks on the lining, they will be cleaned off once finished.
Ben
#213 Jase
Jase
  • 1,166 posts
Posted 15 July 2018 - 04:39 PM
Looks good Ben, I feel your pain this weather. Didn't know the headlining was black in these cars.
#214 gaspen
gaspen
  • 1,194 posts
Posted 15 July 2018 - 04:44 PM
What color is this painted ? I mean what 's the name of the color ? Maybe Bronze Yellow or Britax ?
Edited by gaspen, 15 July 2018 - 04:45 PM.
#215 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 July 2018 - 09:30 PM
They weren't originally. The owner has chosen to have a black headliner.
It is indeed Bronze yellow
#216 gaspen
gaspen
  • 1,194 posts
Posted 16 July 2018 - 05:41 AM
"it is indeed Bronze yellow"
Thanks ! I plan to buy an MK3, this is the color that I choose :)
May I ask you what is the cost of a complete paintwork there ?
#217 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 July 2018 - 05:08 PM
It varies hugely based on how much work is needed before the paint goes on.
Ben
#218 SA-GTS
SA-GTS
  • 17 posts
Posted 18 July 2018 - 06:30 PM
Hi Ben,
Great build, I own a original SA 1978GTS (that I plan on bringing to the uk next year) I did a full rebuild on it only thing I need to change is the arches back to original!
There where quite a few differences between the GT and the GTS, wheel size was 12inch with 7.5 inch discs, the drive train was taken from a cooper s and put in the clubman body, gearbox final drive is 3.44:1 they had higher performance 11stud heads with double valve springs, all had rubber come suspension. They are extremely rare (original ones) as they where only made from 1973-1979, the way to identify a GTS is by the engine number or chassis number.
If you want any photos or info ect ect feel free to message and I’ll help out where I can!
#219 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 July 2018 - 10:16 PM
Hi Ben,
That's great.
Thank you
#220 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 19 July 2018 - 04:04 AM
... wheel size was 12inch with 7.5 inch discs, the drive train was taken from a cooper s and put in the clubman body...
This is not true... much like the GT in the UK, they used 10" Rostyles with a booster and 7.5" discs in the early GTSs, then moving to the 12" steelies and 8.4" discs w/o the booster in the later GTSs. It never used a Cooper S drivetrain either. Rod change gearbox, close ratio gearset, pot joints instead of hardy spicer joints (I think).
Any pictures of your GTS? Would be cool to see :)
#221 SA-GTS
SA-GTS
  • 17 posts
Posted 19 July 2018 - 09:33 AM
I will post the original spec sheet for the GTS, they where made with cooper S replica parts and the block was cast in SA, the boosters where removed around 75/76. I will post photos of my GTS when i get a chance later today.
but for now here is a link to it on facebook... https://www.facebook...29803676&type=3
#222 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 August 2018 - 05:49 PM
Continuing on with the interior..
Last time I was installing the headlining but couldn't continue this morning as I was waiting for a new tin of contact adhesive so I set about cutting the parcel shelf to accept the speakers
And then the speakers. these are the ones that were originally fitted in the front
I then fitted the vinyl to the arch tubs and the rear 1/4 cards
Next up, I fitted the freshened up fuel tank and plumbed it in
And then installed the steering column and some of the dash
A bit sporadic I know, but I'm running out of things to do whilst waiting for the adhesive!
Finally, It did and I finished the headlining
I then started to think about the carpets, insulation and sound deadening.
Nothing is finished yet as I am assessing what needs to be trimmed and seeing how well it fits together.
I have never come across an aftermarket carpet set that fits nicely but this one seems that it will need the least amount of work.
Ben
#223 fiestaharry
fiestaharry
  • 295 posts
Posted 07 August 2018 - 06:01 PM
looking good, what adhesive do you usually use for the headlinings?
#224 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 August 2018 - 06:02 PM
Thanks.
I use Timebond
Ben
#225 JXC Mini GT
JXC Mini GT
  • 890 posts
Posted 07 August 2018 - 06:41 PM
Ben
Looking good Ben, where did you get the carpet set from?
