1275Gt To Sa Gts Replica @ Mill Road Garage Iow
288 replies to this topic
#196 johnR
johnR
  • 2,297 posts
Posted 24 May 2018 - 02:43 PM
Lovely work as usual - it's a shame to have to bolt unrestored parts back onto a pristine shell but I suppose the owner can restore them piecemeal once it's back on the road - and summer doesn't last long in this country!
#197 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 May 2018 - 06:11 PM
Bit more done today
Headliner unpacked
And old one out to remove the rods
Anti drum installed inside the roof
And then the felt
I hung the headliner by it's rods and put some tension into it. Now I will give it some time for the creases and folds to drop out before I fit it fully
Front to rear brake and fuel lines made and installed
And then in with the rear frame with all new trunnions, bushes and fixing bolts
And then I began building up the suspension on one side
Radius arm, adjustable camber brackets, new adjustable shocks, hi-lo's and new knuckles
The aim now is to get it rolling and on it's wheels so once I have finished the back, ill build up the front.
Ben
#198 GraemeC
GraemeC
  • 7,437 posts
Posted 24 May 2018 - 07:38 PM
I have a spare glass probably clips
#199 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 May 2018 - 07:44 PM
Thanks for that.
I may have a couple of old clusters in my shed that I am going to check at the weekend. if not, I will take you up on that!
Ben
#200 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 May 2018 - 05:48 PM
Few more bits on today.
Both arms are now in with back plates and suspension
And I have made up and ran the new hard brake lines and the handbrake cable
I fitted the hubs too once I put in new bearings. They are now Torqued up with new split pins etc.
rear brakes next and then onto the front
#201 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 May 2018 - 06:27 PM
The back end is now complete apart from one of the clevis pins for the handbrake cable
I fitted the steering rack
And then the front frame
Oh and the pedal box
I temporarily fitted the front hubs after building them up with new fixings, bearings and ball joints to the car along with the outer drive shaft CV's, drive flanges and discs so that I could get the wheels on and lower it to the ground
Now I can attack the headlining at a better height although I have had to get some new rods as the new ones just don't have the spring anymore so don't want to stay in place
Some parts are on order now so i need to wait for those before I continue however the front frame will need to come down again before I go too much further as one of the poly bushes has inexplicably split...
#202 Hedgey
Hedgey
  • 179 posts
Posted 01 June 2018 - 01:09 PM
Hi Ben,
Fantastic looking paint job as always and a great read.
I'm going to be spraying my saloon soon in a 2K solid colour with the body and roof being the same colour.
When spraying how do you work your way round the body to avoid dry spots? I.e. where do you start spraying and which areas do you do first?
Also do you have any advice when it comes to spraying the inside of the boot? It looks pretty awkward to use a spray gun in there
Elliott
#203 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 June 2018 - 05:30 PM
Hi Ben,
Elliott
Hi Elliott.
Thanks for the compliments.
When I do a full spray, I use a slower thinner to give me more time but you have to work reasonably quickly.
I start with the roof by painting down in the gutters first all the way round to about 6" in and the tops of the door and window apertures/ tops of the B posts, top of the back panel and top of the windscreen frame and then paint one half of the roof from the gutter to the centre and then round to the other side to paint the other half from the centre to the gutter.
Then I do the lower half of the windscreen frame and scuttle then quickly to the front and start from the centre of the front panel working one way round to the wing, then the a panel then the door shut and quarter panel then the back panel then back up the other side finishing at the centre of the front panel.
I always have a seperate spray gun ready with some fade out thinners to use at the end if needs be to go over the start and end point.
There is no set way, just do what is comfortable. That is just the way I tend to do it. Just make sure you do the underside of the gutters and the tops of the door shuts before the roof on each coat or you may end up with overspray on the roof.
Hope that helps
Ben
#204 Hedgey
Hedgey
  • 179 posts
Posted 01 June 2018 - 07:11 PM
Thanks for taking the time to write that up Ben. I’ll be spraying in a non heated booth at work over a couple of weekends. I might mask off the body and do the roof, boot and engine bay in one sitting. Then do the interior and exterior separately which may make things more manageable for a first time full body respray.
Elliott
#205 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 June 2018 - 07:27 PM
I always paint the underside interior, boot and engine bay seperately to one another and then the outside seperately too.
Scrap that.... I do the engine bay and boot together.
I forgot to say in the last post that I use a Mini HVLP gun for the boot and any other tight areas.
#206 Junior Mini
Junior Mini
  • 313 posts
Posted 13 June 2018 - 08:04 PM
Any news on this one yet Ben?
#207 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,017 posts
Posted 13 June 2018 - 08:22 PM
Yeah Ben, come on, we're getting withdrawal symptoms.   ;-)
#208 Carlos W
Carlos W
  • 10,114 posts
Posted 13 June 2018 - 08:42 PM
The paint is probably curing.
(And he's busy with my car)
#209 CityEPete
CityEPete
  • 3,920 posts
Posted 13 June 2018 - 08:56 PM
I keep checking in, I bet he's sunning himself somewhere nice, lol.
#210 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 13 June 2018 - 09:10 PM
Stunning work love seeing these cars you do come together
