1275Gt To Sa Gts Replica @ Mill Road Garage Iow
#181
Posted 12 May 2018 - 08:46 AM
Ben
#182
Posted 12 May 2018 - 11:29 AM
Wow, how many coats of paint on that Ben?
Three
Looks excellent, Is the paint 2k direct gloss or clear over base.
It's Direct gloss
Sorry to be a pain but what brand is it, that's really flat glass like.
It's probably Nexa. As I had it mixed by my paint supplier, It came in a plain white tin with just a sticker to say the colour name and code.
I can find out for you
#183
Posted 12 May 2018 - 06:17 PM
Thanks Ben, I've heard you mention octoral before and wondered if it's worth spending the extra compared to Ebay paint.
#184
Posted 14 May 2018 - 07:47 AM
Oh man. That. Is. Nice.
I think I'd be terrified to use my car if the paint ever ended up looking that good.
#185
Posted 15 May 2018 - 08:59 PM
Stunning stuff as usual Ben.
#186
Posted 15 May 2018 - 09:13 PM
#187
Posted 18 May 2018 - 05:39 PM
Sorry for the lack of updates this past week. I have had lots of other jobs to tend to but a few bits have been happening on this one.
I wanted to get the headlining unpacked, onto the rods and hanging in the car so that the creases and fold's can drop out which meant installing the roof ariel and front/rear loom
As I bag and tag every single piece and fixing of the car during the strip down, I was going through the bags to find certain fixings so as I was finding clips, bungs and bits, I just put them onto the car as I went so we have some engine bay bits in
And the rear lamps
Unfortunately, things got a bit hectic due to a compressor break down and some delays on another job so I didn't actually manage to get the headliner hung but at least I am ready to do so now.
Ben
#188
Posted 19 May 2018 - 10:05 AM
#189
Posted 23 May 2018 - 06:00 PM
A few more bits have been added to the Mini this afternoon.
I ran the new front loom
Then I installed the dash rails
And the switch panel
And then I added a few more odds and ends under the bonnet
I did spend quite a lot of time working out exactly what parts I will need to do away with the walnut dash and go back to standard.
These include replacement eyeball vents, elbows and tapered covers. I have a frame for the instrument cluster but one of the instrument glass faces is missing and there are no retaining clips on any of them. I also have a replacement plastic cluster cover but no clips... I also need a new front shelf cover and boards
Ill get hold of everything necessary in the next few days.
Ben
#190
Posted 23 May 2018 - 11:16 PM
Absolutely stunning!!
#191
Posted 24 May 2018 - 05:39 AM
What a stunning Clubman! As much as i loved the Poo Brown this will look so nice with the Gts stripes added.
This shell is something else.
#192
Posted 24 May 2018 - 10:31 AM
I love those auxiliary switch panels by the driver.
#193
Posted 24 May 2018 - 12:35 PM
Love your work!
quick question, on page 7 you show the before and after for filling holes, what technique do you use to weld these up? mainly stuff about aerial sized, like on the rear panel.
#194
Posted 24 May 2018 - 01:04 PM
Love your work!
Cheers.
The ariel hole in the back panel was the most involved as the hole had been hacked into the panel so I cut the area out leaving a neat square hole about 2"x2" and then cut a piece of steel to size and butt welded it in forming it to the curve of the panel as required.
The other random holes are just filled with weld using an 8mm thick piece of copper as a backer except for one of the rear bulkhead holes which was too big for that so I made a new piece and fitted it in the same fashion as the ariel hole repair.
Hope that helps
Ben
#195
Posted 24 May 2018 - 01:09 PM
Love your work!
Cheers.
Hope that helps
Ben
cheers Ben!
thats what i've been doing but wasn't sure if you were an absolute ninja at cutting round repair patches as they look so neat haha.
