This shell looks great, still cant believe how original that thing is..
1275Gt To Sa Gts Replica @ Mill Road Garage Iow
#136
Posted 18 April 2018 - 05:55 AM
#137
Posted 23 April 2018 - 06:49 PM
Back on the Mini today.
I have virtually finished rebuilding the inner sill, flitch and toe board and have got the new outer sill on too.
I just need to weld the bottom of the A post boxing panel to the inner sill, finish grinding up the welds on the flitch repair join inside and out and weld the outer sill to the jacking point and it's done.
Then I can get back on with the prep
Ben
#138
Posted 27 April 2018 - 06:54 PM
Hi Ben,
Will you show how you have welded the jacking point to the outer sill?
#139
Posted 28 April 2018 - 10:06 AM
Hi Ben,
Yes, I can do.
Basically, I cleaned up the edges and then fully welded round and tidied up with a carbide burr.
Ill take a photo on Monday.
Ben
#140
Posted 30 April 2018 - 06:45 PM
I finished tidying up the joins on the new piece of inner sill
And then gave the shell another good blow down
And then finished the final little bits of prep ready for primer.
And then primed the inside
The underside
And spot primed some repair sites and bare areas on the topside
Next, I flatted the primer on the underside
And sealed all of the seams
Tomorrow, I shall stonechip the underside ready for some top coat.
Ben
#141
Posted 01 May 2018 - 05:58 PM
A bit more done today.
I started off by stonechipping the underside
And then flatted the primer on the inside of the shell
Before sealing up
Then back to the underside for a taste of the 1970's
I shall paint the inside next and then take it off the spit
Ben
#142
Posted 01 May 2018 - 06:07 PM
#143
Posted 01 May 2018 - 07:33 PM
#144
Posted 01 May 2018 - 08:01 PM
Looks great, what's the thinking with the rough finish to the seam sealant? - as original I presume?
#145
Posted 01 May 2018 - 08:35 PM
You got it.
I just replicated what was there originally but with modern PU sealant.
Ben
#146
Posted 01 May 2018 - 09:18 PM
Nice, is that the same colour as mine Ben - Bracken? Excellent work again, a lovely project.
#147
Posted 02 May 2018 - 07:37 AM
This is Bronze Yellow.
It's growing on me..
#148
Posted 04 May 2018 - 07:27 PM
I have been doing some more painting..
This time, the inside of the shell
First, I taped up the various holes in the bulkhead and floor from the outside and then sheeted up
Then after several rounds of degreasing and dust blowing, It was clean enough to start painting
This colour is really growing on me.
Then finally, once that was baked, I could take it off of the spit
I'm now going to leave it over the weekend to fully harden before I mask off the inside ready for the rest of the painting.
Engine bay and boot next!
Ben
#149
Posted 05 May 2018 - 04:43 AM
#150
Posted 05 May 2018 - 09:10 AM
