Wheel Weights On The Outside Of Rim, Worth It Or Just An Awful Sight?
23 replies to this topic
#16 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 23 February 2018 - 10:37 AM
Looks horrible, I would have asked to have the wights fitted to the inside of the wheel.  Also shouldn't the red dot on the tyre, at the 9 o'clock position in the photo, be lined up next to the valve to reduce the amount of balance weight needed?
#17 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 23 February 2018 - 11:24 AM
100% spot on with red dot, just sloppy fitters.
#18 nicklouse
  • 18,574 posts
Posted 23 February 2018 - 03:50 PM
or no one told them that the red dot take preference over the Yellow.
#19 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 23 February 2018 - 05:25 PM
When I had new tyres fitted to my 7x13 the machine was set to enable the weights to be fitted on the centerline of the rim, this is obviously behind the spokes. They can't be seen and don't interfere with the caliper.
#20 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 23 February 2018 - 10:45 PM
maybe it would be a good idea to balance the wheel without a tire and grind material away (behind the tire surface)?
It's normally the tyre that needs balancing though ...
#21 Cooperman
  • 23,276 posts
Posted 24 February 2018 - 03:03 PM
With 10" alloys it is difficult to fit the weights on the inside as they hit the brake calliper.
#22 thespikeyone
thespikeyone
  • 237 posts
  • Local Club: none yet
Posted 24 February 2018 - 08:26 PM
well i've done a bit of asking around and found someone with a balancer that will calculate for inside only so it would appear that the original fitter was limited due to his machinery.  I have removed the weights without  damaging the paint so will get them re-done.
#23 surfblue
surfblue
  • 1,827 posts
Posted 24 February 2018 - 10:19 PM
I HATE knock on weights on the outside of alloys, they always make a mess of the paint / lacquer. Stick on ones arent much better!
#24 ClassicAsh
ClassicAsh
  • 139 posts
Posted 25 February 2018 - 05:47 AM
Weights on the outer do look crap, Had mine fitted on the inside when I restored my wheels, they used the stick on ones, have to say when I checked under the car a few weeks ago most of the weights that where there have disappeared ! but I haven't noticed and problems or vibrations. so they will stay like that until I fit new tyres again, by my reckoning it will be about 5 years from now.
