Spi 1995 Huge Consumption, And Technical Control Refused
Best Answer gdudu , 27 October 2018 - 10:48 AM
Hello
Good new, the technical control for pollution was OK, The CO was about 0.3  :-)
Bad news :
The technical control was not accepted cause of oil drops. The new rules don't accep this, and the techicien told me that with an english car it would be impossible .... :angry:  :angry:  :angry:
And now, I have a problem when I accelerate : there is a big hole and the motor loses all power and frequently stalls
I have reseted the ECU with readmems (readmems.exe com3 interactive and OxFA), but this is the same
I have made a little log file attached
Go to the full post
156 replies to this topic
#151 Screwdriver
Screwdriver
  • 281 posts
Posted 28 November 2018 - 09:11 AM
My SPI uses between 9-11 liters per 100 kms. Is this not normal?
#152 hungdynasty
hungdynasty
  • 173 posts
Posted 28 November 2018 - 10:43 AM
My 98 JDM, around 7 litre/100km with air conditioning on, around 6 litre/100km AC off.
#153 genpop
genpop
  • 508 posts
Posted 28 November 2018 - 12:36 PM
seems to run in limp mode, check your o2 sensor!
#154 gdudu
gdudu
  • 54 posts
Posted 28 November 2018 - 03:35 PM
Well
All seem to be OK now
I have buy some bad capilary tube, it was not very good
Now it's OK the idle KPA is about 30 and STFT is moving, and lambda also
See the log file, perhaps some little adjustments to make ?
#155 genpop
genpop
  • 508 posts
Posted 29 November 2018 - 09:46 AM
Hi gdudu,
looks good now, IAC and RPM could be a bit lower.Ask Sprocket how to tune that. Drive the car for a while and give feedback about the fuel consumption (with logfile!)
#156 martinrub
martinrub
  • 50 posts
Posted 29 November 2018 - 11:21 AM
Gdudu
Has the black smoke on startup now disappeared?
#157 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 29 November 2018 - 01:42 PM
My 1993 SPI 53 PS runs with 6-6.5 Liters a hundred km. Reason for high consumption: Lambda, Coolant temperature sensor and the vac hoses which should be replaced  with silicon for safety reasons.
