Spi 1995 Huge Consumption, And Technical Control Refused
Best Answer gdudu , 27 October 2018 - 10:48 AM
Hello
Good new, the technical control for pollution was OK, The CO was about 0.3  :-)
Bad news :
The technical control was not accepted cause of oil drops. The new rules don't accep this, and the techicien told me that with an english car it would be impossible .... :angry:  :angry:  :angry:
And now, I have a problem when I accelerate : there is a big hole and the motor loses all power and frequently stalls
I have reseted the ECU with readmems (readmems.exe com3 interactive and OxFA), but this is the same
I have made a little log file attached
Go to the full post
156 replies to this topic
#136 gdudu
gdudu
  • 54 posts
Posted 24 October 2018 - 12:52 PM
Hello
Sorry for the non answer, but, no my problem was not solved
I will replace soon the cat and will tell you the result
#137 genpop
genpop
  • 536 posts
Posted 24 October 2018 - 04:59 PM
Hi gdudu,
will you please publish your logfile after changing the cat.
#138 gdudu
gdudu
  • 54 posts
Posted 27 October 2018 - 10:48 AM   Best Answer
Hello
Bad news :
Edited by gdudu, 27 October 2018 - 04:36 PM.
#139 genpop
genpop
  • 536 posts
Posted 27 October 2018 - 12:06 PM
Hi gdudu,
the only thing I see is your stfueltrim its a bit low (lean),would be better when being over 100 (rich). Have the engine running for a while after reset, better do the log file while driving.
But have a look what Sprocket says to your logfile :-)
And how did the old cat look like (inside)?
#140 martinrub
martinrub
  • 50 posts
Posted 27 October 2018 - 12:08 PM
No more black smoke on startup?
Do you have the fuel-pressure gauge? Your loss of power on acceleration could be because of low fuel pressure. You should check the pressure at idle and then when you accelerate - dies the engine have loss of power when you open the throttle also with car stationary or does it have to be accelerating under load (moving)?
I’ve not looked at the logfile yet.
Edited by martinrub, 27 October 2018 - 12:54 PM.
#141 genpop
genpop
  • 536 posts
Posted 27 October 2018 - 03:47 PM
Hi gdudu,
Sorry I'm wrong, its running sligthly rich!!That would be ok.  Wait what Sprocket thinks!
#142 gdudu
gdudu
  • 54 posts
Posted 27 October 2018 - 05:01 PM
Yes, black smoke is stil here, but I think this is something else, not really boring
I don't think it's the fuel pressure, cause it was good not long ago
The old cat seems to be normal. I would like to post a picture, but I cannot, I think I have posted too much files an images in this topic and the size is limited
I had an old problem I wanted to correct since a long time : Idle was not very fast to come back after releasing the pedal. (it was difficult to drive with motor at 2000 rpm when switching gears). Then I replaced the accelerator cable.
But it was not this.
Then I tried to modify settings, like igniton_advance, fuel_trim, idle_decay or idle_speed. But it was not better and now I have this hole when acceleration.
Then I reseted MEMS, but not sure it was effective
I will try to make a new log to morrow, now it's raining
Edited by gdudu, 27 October 2018 - 05:02 PM.
#143 gdudu
gdudu
  • 54 posts
Posted 28 October 2018 - 11:11 AM
Well, I cannot post any picture or file, the topic is full
But I have checked my capilary tubes, and the one between the ECU and the fuel trap was broken. I have changed it with a cristal tube, but this is not better. I think I have to buy a new one
#144 genpop
genpop
  • 536 posts
Posted 28 October 2018 - 01:16 PM
when have you done the logfile, at that time the tubes must have been ok . Map is always at about 30 while rpm is about 900.
But we need a logfile while driving!
#145 gdudu
gdudu
  • 54 posts
Posted 13 November 2018 - 07:13 PM
Then I have a big hole when I accelerate, and the motor loses all power and frequently stalls
Here's a log file when driving.
I still have a crystal tube instaed of the original capilary tubes (this is less rigid)
The Map Kpa is always above 30
Here I really don't see what it is
#146 genpop
genpop
  • 536 posts
Posted 14 November 2018 - 07:02 AM
Have a look to your IAC, seems to be open all the time!
#147 gdudu
gdudu
  • 54 posts
Posted 25 November 2018 - 09:51 PM
Well, this is OK now,
My cristal tube between the ECU and the fuel trap was stucked and then closed
I still have to see why the idle is not coming back quicly : when I release the accelerator, motor is still running and it come back to idle after 1 or 2 seconds, then it's a little hard to drive when switching gears (motor is going very fast). Perhaps I will put a spring to call it back faster
And tonigth the hand brake was broken when I pulled it, but this is something else ...
#148 gdudu
gdudu
  • 54 posts
Posted 27 November 2018 - 03:19 PM
Hi
It's OK for the idle : my accelerator cable was not tight enough, and now it's OK
I thougth to arrive at the end, but
I have made a "last" log file to see, but I think to have something wrong : the STFT is always at 100, it doesn't move ???
The lamda seem to be OK
During this log file, I have made some settings on the cable, that's why the idle is moving, this is normal
Could someone help me , perhaps as is normal ?
#149 genpop
genpop
  • 536 posts
Posted 27 November 2018 - 06:35 PM
Hi gdudu,
a lot of things go wrong here, when I have a look to lambda status and closed loop ,both are at zero all the time, so short time fueltrim will not work.Possibly your lambda sensor defekt or not connected right, maybe no heating.Check if there is current between the two white cables.
In addition iac is not going under 60 steps, should decrease to 20 to 30 when engine is idling. Map is bad too, should be at about 30 in your region when car is idling.
genpop
#150 gdudu
gdudu
  • 54 posts
Posted 27 November 2018 - 09:22 PM
Ohhhh
That's very odd, all theses problems when my car seem to go well
I will try to check some connections, all the sensor cannot be wrong at the same time
Thanks genpop, will check
